Metal gear question
I have a 35cc 2stroke engine in my rc and it has all metal gears in the gearbox. Do I need to lubricate it? My local hobby shop said that I didn’t need to. I highly doubt that because my previous gears stripped
All metal gears? I would certainly lubricate it and make sure the mesh is set correctly. It's good to see that they're covered.
I like to use lubricants that have very high film / surface tension strength on metal gears. Chainsaw bar lubricant is excellent as it sticks to metal like crazy. You'll be able to see it "string" after applying it to the gear and rotating. Normal oils or lubricants will likely get flung out from centrifugal force in a short amount of time. |
Dry lubricants would be better for a spur gear setup as it won’t attract dirt like a sticky oil would. Save the bar oil for the air filter and use graphite or a spray on fast drying dry lubricant. That is, if the manufacturer recommends it.
I haven’t tried dry lubricant spray but that sounds promising. How well does it hold onto spinning surfaces?
Ok thanks for the answers. I’ll try using dry lube
I’m not a fan of WD40 products, but they have a dry lube that seems to work okay. It sprays on wet and dries quickly. My favorite dry lubricant was a product made by Borden called Slide All. The Borden brand was discontinued, but Elmers now has their name on it. The old stuff had Teflon in it (which causes cancer I guess) and it worked slick. Not sure how the new stuff is if it’s the same recipe or not, but it’s the same premise as the WD40 dry lubricant. You could also dry silicone lubricant too. That stuff doesn’t leave much residue either.
I am intrigued by the use of dry lubes for all our rc stuff - I never thought they'd have a dry-lube film. I found this that is supposed to "bond instantly to metal, rubber, plastic and most substrates to form a dirt repelling barrier..). I ordered a can to try. Thanks for the tip Qwksport!
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
Thread Tools | |
Similar Threads | |||||
Discussion | metal gear servo questions | sanddragon2004 | Beginner Training Area (Heli-Electric) | 3 | Apr 27, 2012 05:55 PM |
Discussion | SERVOS-Metal Gear Or No Metal Gear? | Skywolf | Radios | 3 | May 09, 2010 07:00 AM |
Discussion | Metal gear servo's - All metal gears? Hyperion sets a new standard! | SpeedVision | Electric Heli Talk | 20 | Jun 03, 2009 08:46 PM |
Hitech servo gear question will the hs81 metal gears fit into the hs81 | Sloop | Radios | 3 | Feb 02, 2004 04:58 PM | |
Non-metal gear servo question for Corona | ViperR | Electric Heli Talk | 5 | Sep 28, 2003 11:48 AM |
