Sep 22, 2020, 05:20 PM
Latitudes vs Attitudes
Bob Gaito's Avatar
Oh- did you do that while I was typing?
OK then slide the shaft in and line up as mentioned above( remember all 4 parameters)-then you can cut a hole for the shaft-slide the shaft into the hull and check everything with the prop and rudder installed-if its good then widen the hole enough for the stuffing tube to slide in-keep checking after each step.
BTW put that protractor back in the drawer-please.
Sep 23, 2020, 01:43 PM
Diamond Bar, CA
Donjamin's Avatar
So MACK makes a small shaft strut (smaller in height) called an ST11. The ones MACK sent me are an ST21. I just placed an order for the ST11 which will give me a lower and better angle to the prop shaft.
Sorry Bob, I do like my protractor...
Don
Sep 23, 2020, 06:48 PM
Bob Gaito's Avatar
Lol..you'll be so glad that you didn't do 16 degrees..
Oct 28, 2020, 04:46 PM
Diamond Bar, CA
Donjamin's Avatar
It has been a few weeks since I last posted. My wife and I made several camping trips and we are now back in town. Iíve made a bit of progress building out the upper deck structure. See pictures.
Iíve also received a new set of skag mounts for the boat. MACK Products sent me a set of ST-11ís which are shorter in height. Iíll be fitting to next when I finish with the boats upper deck structure.
D
Help! sterling 63 chris craft windward Scale Boats 126 May 03, 2016 01:42 PM
Build Log Sterling Chris Craft 63' - Continued Bulding Charley L. Scale Boats 48 May 14, 2010 09:22 PM
Discussion 63' Chris-Craft Cruiser by Sterling USA 236 Scale Boats 66 Jul 06, 2009 09:04 AM
Build Log Sterling 63' Chris Craft Restoration strapats Scale Boats 295 Sep 27, 2008 12:21 PM
