Apr 28, 2005, 02:06 AM
eta
eta
fly fly fly...
eta's Avatar
ESC cut-off voltage for 3S lipo?
I got 1 Phoenix 10 and 1 Phoenix 25 ESC. According to the 2 manuals, the Ph 10 says the ESC cut-off voltage for 3s lipo should be 9V while the Ph 25 says the ESC cut-off is 7.2V. Any idea which one would be more appropriate?
Thanks.
Apr 28, 2005, 02:39 AM
myk
myk
myk's Avatar
9v
Apr 28, 2005, 05:42 AM
Valid8r
Valid8r's Avatar
There are a lot of threads on this in the CC vendor forum and there does not appear to be consensus on this issue. I too am waiting to see what the real answer is.
Jon
Apr 28, 2005, 06:20 AM
vintage1's Avatar
I'd use the 9v on soft cutoff and the 7.2v on hard. Especially with some vendors packs where '15C' and '20C'; ratings means volts drop to around 2.5v per cell under load.
Apr 28, 2005, 06:55 AM
Southern Pride
everydayflyer's Avatar
Jon
Wrong answer. Thunder Power and Apogee both state very clearly that their batteries must not be used with a LVC below 3.0 volts per cell.
The 2.4 or 2.5 volts per cell was (is) OK for gen 1 LiPolys but will severely damage the now generation of LiPolys from most manufactures. Kokam may still recommend (approve) odf a low LVC,I am not sure.
LVC as explained by Castle Creations.
Charles
Discussion Lithium cut off voltage For Hyperion ESC? gpang788 Power Systems 4 Apr 28, 2007 02:05 PM
Question Cut off question for 2cell lipo, 5.2 volts? zippiz Batteries and Chargers 22 Jul 16, 2006 12:05 AM
What cut off voltage for 3 lipos? rcmann Parkflyers 3 Oct 21, 2005 08:04 PM
Idea Ultrafly Typoon-25A ESC Cut-off Voltage SuperHornet Batteries and Chargers 1 Jun 02, 2005 06:30 AM
Cut off voltage for Li batteries w/Phoenix 25 gquiring Batteries and Chargers 5 Oct 13, 2003 07:17 PM
