This thread is privately moderated by Scale330l, who may elect to delete unwanted replies.
Jun 30, 2020, 02:28 PM
Trader Rating: 353
FlyitAgain RC
Scale330l's Avatar
$75.00 USD
Buyer pays shipping
For Sale
Flight Works Turbine Fuel Pump
Selling this nice turbine fuel pump.
Flight Works Model 200.
Specs:
Flightworks Fuel Pump. As an improved version ofthe older Model 200-B, the Model 200-C is recommended for turbines up to 20 lbs (9.0 kg / 89 N) thrust. Additionally, it is well suited for the smaller turbines such as the Wren Turbine MW44, MW 54, Jet Central Rabbit, Merlin M-90, Kingtech K-80E. It works well with the FADEC ECU as well as with the Orbit ECU. Included and factory installed: . As with allFlightworks pumps, it features extremely high precision stainless steel gears, unique floating drive gear design and a hard anodized aluminum body. It has a very low current consumption compared to the bigger pumps. You should use a high quality fuel filter on the inlet side (suction line, before the pump). We recommend you use the Hanger 9 Fuel Filter available in our "Accessories" section. . The pump does not require any break in and is ready to use. It can be installed in any orientation with the included mounting bracket and hardware. Characteristics:. Weight: 44 g (1.5 oz). Diameter: 20.0 mm. Length (not including barbed fittings): 44.5 mm. Bypass valve or regulator required: No. RF suppression included: Yes, RF PCB installed. Mounting bracket included: Yes, Stainless steel. High precision stainless steel gears and hard anodized aluminum body. Min. start voltage: 0.70 0.15 Volts. Open flow rate: Approx. 600 ml/min.
Asking 75.00 plus alittle shipping.
Sold Flight Works Turbine Fuel Pump Scale330l Aircraft - Fuel - Jets (FS/W) 0 Jun 23, 2020 02:54 PM
Question Cermark electric fuel pump won't work johngr Beginner Training Area (Fuel) 6 Jun 22, 2016 02:02 PM
Discussion Motor for Turbine Fuel pump voodoodb Jet Turbines 2 Jun 14, 2011 10:49 PM
Found Flight Works Fuel Pump xwingnut Aircraft - Fuel - Jets (FS/W) 0 May 03, 2009 08:52 AM
For Sale Flightworks Turbine Fuel Pump orion23 Aircraft - Fuel - Engines and Accessories (FS/W) 0 Sep 07, 2008 02:31 PM
