I re-trimmed the Plover with the heavier nose, and got the good glide back.
Kevin |
I'll try a low power catapult launch, and see. Plan B may be in adding a smaller wing up front.
Kevin |
It really doesn't need a canard surface. You've got more than enough sweep to put the rear part far enough away from the main area.
But that does not mean that the interplay between the balance point and amount of reflex used with up trim in the elevators won't be sensitive. Small changes will likely have a big effect when you start playing with the catapult launching. |
What do you mean by the term "reflex"?
Kevin |
I mentioned it in an earlier post that all of our models have some reflex in the horizontal surfaces. On conventional planes it is the slight negative angle of the stabilizer with respect to the wing. On flying wings it can come from washout or washin or from some reflex in the camber line of the airfoil. Or on flying wings with symmetrical airfoils simply a tad of up trim on the elevons.
In your Plover's case it would be from a little up trim in your center rear elevator tabs. |
Great. I will remember that when I take it out for a trial flight. As is at this point I'm very pleased with the Plover.
Kevin |
Pink = the "reflex" area.....in all cases positioned well aft of the centre of pressure.... The principle is the same on all three examples. |
Reflex refers to elevators for a flying wing while decalage refers to the incidence of an airplane stabilizer compared to it's wing?
Kevin |
The illustration explains the physics well.
Kevin |
Zaic 37 yearbook Grant Logan pusher glider
Here's my entry, a 1937 pusher glider. It has a 15" wingspan. Flies great! Downloaded the plan from Outerzone
Reason: Added plan location
Looks cool. Is there a plan available?
Kevin |
Great discussion, so much can be learned from such a simple project. At some point I will try a Plover, it's been interesting to follow Kevin's build and trials. My next one though will be the that pusher by Grant Logan, Randy, you beat me to it. My first is the Outdoor Glider by Joe Hervat from 1944. (Oz2019)
Thread Tools | |
Similar Threads | |||||
Poll | Vote for a theme for the First FF Forum Small Project Build | BMatthews | Free Flight | 13 | Jul 03, 2020 03:28 PM |
Discussion | Any interest in a series of FF forum theme builds? | BMatthews | Free Flight | 52 | Jun 28, 2020 02:06 AM |
Discussion | the Future of the Vintage Forum theme build? | BMatthews | Vintage & Old-Timer Designs | 65 | Mar 04, 2018 01:37 AM |
Build Log | Sig "FLIP" hand-launch FF balsa glider with modifications | Pauliwog | Free Flight | 7 | Mar 30, 2011 11:50 PM |
Discussion | First time posting here...first balsa build FF. | CooHead | Free Flight | 17 | Aug 30, 2009 08:16 PM |
