May 05, 2021, 12:00 PM
dtx66's Avatar
Hi !
I can not find any setting information even NAN‘s official web site.
Does anyone can help ?V-tail is preferred.
Thanks !
May 05, 2021, 12:27 PM
Tuomo's Avatar
Elevator +/- 12 deg, rudder L/R 18 deg.
I fly currently CG @102mm. If you have rearward CG you might want to reduce elevator movements. Rudder is quite powerful with these settings.
Wing is about the same as with x-tail fuse. The longer span versions benefit from slightly more aileron differential (as obvious).
Originally Posted by dtx66
Hi !
Thanks !
May 06, 2021, 01:01 AM
dtx66's Avatar
Thanks Tuomo !
I found that most of NAN's model use same wing setting as below (BF, EXP, XPL 3, etc. ):
maybe I can use this for start
Left [mm] Right [mm] Up [mm] Down [mm] Butterfly [mm]
Ailerons Up 13 13 – – 10
Down 8 8 – – –
Flaps Up – – – – –
Down – – – – MAX
Video IDS install on NAN Models Explorer BF sonicbenj Electric Competition Soaring-F5J/F5K/ALES/E-Soaring 34 Sep 16, 2020 06:52 PM
Discussion Explorer - new F5J model at NAN (with an 'E') gdouglas Electric Competition Soaring-F5J/F5K/ALES/E-Soaring 68 Nov 05, 2019 02:35 PM
Discussion 2019 Eastern USA Scale Soaring Schedule - come out and fly with us! SPasierb Scale Sailplanes 17 Sep 09, 2019 07:30 AM
Build Log Nan Xplorer 2.5 Electric 3.8 meter Sailplane from Soaring USA FlyingGorilla83 Multi Task F3X 3 Jul 20, 2015 09:22 PM
Mini-Review Soaring USA bag for Explorer 4.0 Hoot Multi Task F3X 7 Jun 21, 2011 01:48 PM
