Jun 27, 2020, 05:47 AM
Video
Insta360 Go 18gram HD Stabilised camera
wonderful super light & stable camera that is ideal for FPV ( 5 min. Recording) can be mounted on both small & large RV aircraft.
Multi position footage
Turbo Timber +Insta360 GO -1st RC Aircraft test...How good is it! (5 min 14 sec)
Jun 27, 2020, 06:50 AM
Pixelpeter's Avatar
Looks pretty cool, especially coming from such a tiny camera.
There is a lot of 'wobbling' going here and there though; vibrations meet high shutter speeds?
AndyRC tried one too on his quads:
Insta360 Go For FPV (13 min 52 sec)
And he too had jello problems.
Jul 01, 2020, 07:52 PM
A-10 Flights...with the Inst360 Go
Great camera using various angles
https://youtu.be/rh8dLnoE8EU
Jul 02, 2020, 03:10 AM
Pixelpeter's Avatar
Overal the stabilisation is pretty impressive.
You must be really glad that you can now record 5 min 'FPV' clips
Jul 02, 2020, 07:49 AM
The main reason I purchased this camera
Yes indeed. Prior to this the max recording was 1 min.
Today flying the Cherokee over some very bumpy winds. On one flight I spent too much time on the ground with the record on & used up all the memory on 1 clip.
It was great fun
E-Flite Piper Cherokee with Insta360 GO Multicam (4 min 17 sec)
Jul 02, 2020, 12:09 PM
Pixelpeter's Avatar
Kinda weird that in the frontal view shots there is quite a bit of 'wobble' going on, while in the tail and wing views there is hardly any. Depends on the way the camera is mounted? Or maybe on what material?
Jul 02, 2020, 07:09 PM
Mounting the GO
Yes. I now use 3M double sided thin tape rather than the Velcro . Velcro wobbles about too much but the tape is solid as.
I will keep looking for an alternative but, as you can see, you cannot have anything in front due to the wide angle lens. Of course you can change the view settings.
Jul 09, 2020, 08:57 AM
New aircraft to try the `18 gram camera
This video is the Hawker Tempest small aircraft and fitted with the Insta360 GO 18 gram Multicam
HK HAWKER TEMPEST MAIDEN with Insta360 GO Multicam (3 min 46 sec)
Jul 09, 2020, 10:15 AM
Pixelpeter's Avatar
Beautiful plane.
How is the workflow on the Insta360 Go, especially combining multiple views plus shots from other cameras.
I really don't like to be so reliant on a phone when it comes to cameras
Jul 09, 2020, 06:55 PM
Workflow
Found the insta app great to trim the footage & format to FCX for editing. I only use the iPhone to check the shots at the field.
The little self adhesive ring I use to mount the camera on aircraft works quite well & so secure.
Jul 10, 2020, 01:08 AM
Beautiful plane.
You do basic go and 360+reframe edit, though Insta360 software is quite good and regularly updated as well as their desktop counterpart.
OF COURSE to make more complex edit adding other cameras, you need something else.
So far pretty happy with insta360 soft update + their customer service (they sent me free of charge a replacement battery for the insta360 one X after mine swallowed after 15 months of use).
Jul 10, 2020, 02:28 AM
Pixelpeter's Avatar
Can you get the files off your phone rightaway on your computer, or do you always need to go thru the Insta360 app to convert them first?
Jul 10, 2020, 06:40 AM
Just tried, yes, you need the camera in the recharging cradle thanon top of that -> usb connection to the pc and then you can access the files like a regular sd card connected to the pc.
You still need to address the 2700x2700 file somehow, it can play like a superfisheyed on VLC but on Insta360Studio 2020 free desktop software is fine.
Insta360 Studio 2020 Tutorial (8 min 0 sec)
Have not tried if can also do camera alone through bluetooth to laptop.
Jul 10, 2020, 06:54 AM
Pixelpeter's Avatar
Aha, thanks.
Jul 10, 2020, 07:43 AM
The Twin Otter using the insta 360 GO
As mentioned , I check the footage at the field then at home transfer each, trim & save to the Mac on the converted mp4 files ready to complete full editing.
Great steady camera with the RC Jets & Prop aircraft bouncing around....here is the latest
E-Flite Twin Otter Insta360 GO Multicam Views (5 min 16 sec)
News Insta360 GO FPV Mode Jason Cole FPV Talk 42 Sep 11, 2020 02:55 PM
Discussion Insta360 Go - 20gram image stabilized HD Camera jonE5 FPV Talk 3 May 12, 2020 12:51 AM
Discussion Beautiful video with GO Pro HD camera jeanclaude Sailplane Talk 8 Feb 04, 2010 11:26 PM
Discussion HD camera shootout. Aiptek GO HD versus the older Aiptek 720p randall1959 Aerial Photography 10 Nov 15, 2009 05:26 PM
