The Spin EL is a new 1M size electric glider. It looks a lot like a hand launch glider, but is perfect for those who are not able to perform a good discus launch. The Spin EL should thermal well, fly fast and work nicely on a slope too. It sounds like a great sport glider and you know it will perform well with airfoil work from Joe Wurts. The Spin EL comes 99% ready to go right out of the box with about an hour of work needed to get it ready to fly.
Construction is composite materials with a carbon fiber boom and plastic fuse that has pre-installed pushrods for the elevator and rudder inside. The wing is also carbon, with a Rohacell foam core, carbon spar cap, carboline spar shear webbing and carboline skin. The horizontal stab pylon is already mounted and the ailerons are pre-hinged making it fast and easy to finish assembly for flight. Kennedy Composites should have some in stock at the end of July with a nice selection of colors to choose from. Pricing is $369.
Thread Tools |
Really looking forward to this one.
For those looking for more information and specs, here is the link to Valdimirs Models, the manufacturer of the Spin EL.
Vladimir's Spin EL |
What is the blue fuselage material? Description says carbon fiber but it looks like 3D printed plastic?
![]() Spin El fuselage Fuselage construction based on Hi-Tech prepreg carbon boom with impact PA fairing and nosecone with canopy. You will be surprised at the ease of servo installation. Your friend never believe you, the where are 4 servos, battery, receiver and motor inside. Carbon elevator and ruder rods is installed already and has ready installed rod ends for fit to the horns. Horizontal stabilizer pylon is glued already and the boom has ready slot for the fin installation. What is PA plastic? TECAMID / TECAST Ensinger Plastics PA material, polyamide or commonly called nylon, is manufactured by Ensinger in standard stock shapes for machining in sheet, rod and tube. ... Generally speaking, PA Nylon is a semi crystalline thermoplastic with low density and high thermal stability. |
Thanks, missed this detail. Found it on the creator's website, in an inconspicuous tab, towards the bottom of the page. These days you really have to do some digging and read everything to ensure getting what you thought you're getting.
On the distributor's page: "The carbon fuselage is fully assembled with pre-installed pushrods for elevator and rudder." LOL |
The problem with the world is that some people have very fragile ego's and would double down and try to gas light you that not only that no mistake was ever made but it is the whistle blower's fault for pointing out the "mistake." Kudos to you. |
Wouldn't that be nice .. heavy enough for heavy wind days and power-up when there seems to be no lift around without moving the weight around.
Thread Tools | |
Similar Threads | |||||
Discussion | Spin EL - Kennedy Composites | Blaster | Electric Sailplanes | 12 | Sep 01, 2020 05:27 PM |
New Product | Hobby People QUEST 2.1M EPO Glider w/ 4 Servo Wing, RxR & RTF | Doubletap | Foamies (Kits) | 6 | Feb 17, 2016 05:26 PM |
New Product | Hobby People QUEST 2.1M EPO Glider w/ 4 Servo Wing | Doubletap | Electric Sailplanes | 0 | Nov 02, 2015 11:41 AM |
Discussion | Alpha-EV 1M Electric Glider | eaman | Beginner Training Area (Aircraft-Electric) | 2 | Jun 03, 2014 07:33 PM |
Any 1m electric glider plans ? | Pook | Electric Sailplanes | 4 | Apr 07, 2005 07:18 PM |
