H-King Hawker Tempest 800mm (31.5") PNF
This H-King version of the thoroughbred Hawker Tempest warbird is manufactured in a superbly finished EPO foam and an authentic World War ll D-Day invasion stripe color scheme plus all the decals are factory applied. The Hawker Tempest comes with motor, ESC and servos pre-installed and also a built in 6 axis ORX flight stabilization system to make it even easier to fly. The stabilization uses a 32bit MCU and a 6 axis digital gyro for ultra fast control response, it can also be switched from beginners mode to expert mode.
The H-King Hawker Tempest is based on a Mk V clipped wing version that came into service in 1944. The Tempest is a later version of the Typhoon which was found to lack performance at altitude. They fitted a new thinner laminar flow wing which gave it a marked improvement over the Typhoon even with the same Napier Sabre engine. The Tempest was at the forefront of the battle against the V1 flying bombs flying at low level. The Tempest emerged as one of the most powerful fighters of World War II and was the fastest single-engine propeller-driven aircraft of the war at low altitude. The markings of the H-King Tempest JN751 RB depicts the aircraft that was flown by Wg Cdr R.P.Beaumont OC of 150 Wing based at Newchurch in England in 1944. In this particular aircraft Beaumont scored most of his 31 V1 claims including the very first air-to-air claim on 8th June 1944. There is little to build with the H-King Hawker Tempest, it comes 97% pre-built and as mentioned before it has the motor, ESC, servos and the ORX pre-installed. All you need to do is fit the main wing, tail assembly and plug in the main landing gear. To complete the model you require your own transmitter, receiver and flight battery, after that everything else is included. It has the power to do all the maneuvers required for a World War II fighter and looks fantastic in the air. The stabilization system makes it very smooth and easy to fly and because of it's size it is perfect for local parks, large indoor areas or the local flying patch. Features: • Authentic scale detail • Outstanding flight characteristics • Fitted with ORX flight stabilizer with 2 different flight modes (Beginner and Expert) • Efficient 4 blade propeller • High torque brushless motor • Complete high-quality hardware package Specs: Wing Span: 800mm (31.5”) Length: 678mm (26.75”) Weight: 455g Thrust rate: 1:1 Motor: 2408-1200KV brushless ESC: 20A brushless Gyro: Intelligent 6-axis and 2 flight modes (beginner-expert) Servo: 9g x 4 Propeller: 8x6 4 blade Required: 5ch or more radio and receiver system 11.1V 800mAh 15C LiPo Battery (JST Connector) Suitable Li-Poly charger
Excellent choice for a re-pop. By all accounts a good plane.
Probably the mini retracts, the same as in this video on the Mustang........
Hopefully they bring the T-34 next. LURCH |
Beautiful bird!
Latest blog entry: FMS Discount Codes! Click here!
It's the smallest one from HK, wheels sanded down to fit in the wing, wheel covers are used as well.
Now thats tempting! I love retracts.
i ordered mine the moment i got the email....i love the p51 moonbeam...Hope this flies just as well....
Thread Tools | |
Similar Threads | |||||
New Product | H-King A-1 Skyraider 800mm (31.5") PnF w/ORX Flight Stabilizer | Andy852 | Electric Warbirds | 755 | Mar 21, 2024 09:10 PM |
Discussion | H-King Volador - Glue-N-Go - EPP 800mm | rosnik | 3D Foamies | 16 | Nov 12, 2020 04:47 PM |
Discussion | Airfield Hawker Tempest 800mm | Brad Peters | Electric Warbirds | 17 | May 13, 2019 01:41 AM |
Build Log | Dynam hawker tempest 5 to tempest 2 radial conversion | rob66 | Electric Warbirds | 2 | May 26, 2016 06:51 AM |
