Jun 09, 2020, 10:47 AM
Your trash, my treasure
fepsphan's Avatar
Help!
Radio master tx16s
Just bought the radio and canít figure out how to make the frsky djt module work. The modules lights do not turn on. Any suggestions?
Jun 09, 2020, 11:13 AM
!= International Arms Dealer
visioneer_one's Avatar
enable the external module and set the type to PPM. Binding etc. will be accomplished by using the F/S button on the back of the module.
question. Is there a reason you're not using the built-in multimodule?
Jun 09, 2020, 11:14 AM
Eury's Avatar
Are you plugging in an external module vs just using the internal? If so you go to the model screen where you name the model, scroll all the way to the bottom and turn on the external RF and select PPM.
Or you could just use the internal one that it came with.
Jun 09, 2020, 11:38 AM
fepsphan's Avatar
Ummm I didn’t know I could. I thought it was there to swap out modules. So how do I do that? I have to redo all my planes?
Jun 09, 2020, 11:39 AM
fepsphan's Avatar
I see someone else said that too. How do I bind it with my rxs?
Jun 09, 2020, 12:26 PM
OK I think I get what you're asking
is it that your existing planes are already bound to your FrSky DJT module?
If so then enabling external RF and setting it to PPM will activate the module which will continue to work like it did in your (previous) radio. No rebinding will be necessary.
you'll also not have model match or telemetry...
Binding your receivers to the internal module is simple enough. Enable the internal module, set the mode to MULTI (should come up automatically on current Radiomaster or Jumper radios) then set the sub-protocol, options, channel range and receiver number to whatever matches up with the receiver you're using. You then put the receiver in bind mode then select Bind on the transmitter.
(click for jumbo)
In the above example I'd just bound up a Jumper R1 receiver. The mode is MULTI, the subprotocol is FrSky X2, the protocol option is LBT (EU) the channel range is CH1 - CH16, the receiver number is 0
Jun 09, 2020, 03:24 PM
fepsphan's Avatar
(click for jumbo)
These are the rxs I have. I canít get it to work
New Product RadioMaster - TX16S 16Ch 2.4ghz Multi-Protocol OpenTX Radio System Hobby Porter Radios 10539 Today 02:08 PM
News Radio Carbon Art Thermal Soaring Master Class 2 Jason Cole Sailplane Talk 2 Aug 04, 2017 08:30 PM
News Thermal Master Class 2 - Radio Carbon Art Productions Jim T. Graham Sailplane Talk 6 Jul 24, 2017 12:25 PM
News Radio Carbon Art's Thermal Soaring Master Class is Here Jason Cole Sailplane Talk 6 Jul 19, 2016 05:39 AM
Discussion Master Gain On Radio bcbradford Eagle Tree Systems 0 Feb 23, 2016 12:25 PM
