Jun 05, 2020, 03:09 PM
biomecanoid's Avatar
FS-GR3E issue - Throttle full when radio is booting
Hello,
The car in question is a Remo Smax and i used the following parts:
Motor
https://www.ebay.com/itm/Surpass-284...72.m2749.l2649
Robinson Reducer Sleeve 5mm-1/8"
https://www.ebay.com/itm/323582654809
Receiver:
https://www.ebay.com/itm/Flysky-FS-G...AAAOSwgv5ZeFl3
The car feels fast and powerful but i think i am having an issue with the Flysky-FS-GR3E:
If i leave the car running and turn off the iRangeX Transmitter the car stops which means i have setup successfully the failsafe but when i turn on the transmitter for the few 1-2 seconds that the transmitter boots its firmware the car turns on throttle full blast and stops when the transmitter is finished booting, whats up with that ?? i have lots of models with an FS-GR3E receiver and never had an issue.
Its the receiver malfunctioning ? did i program that behavior by mistake ? any ideas are welcome
Thank you
Chris
Jun 06, 2020, 07:33 AM
Did I make the A Main?
bill_delong's Avatar
Sounds like you need to reset the fail safe per the instructions with the radio.
Never a good idea to have the radio off unless the car is turned off first.
Jun 06, 2020, 04:31 PM
The way i set the failsafe is by pressing the button on the receiver.
When i drive the car and turn off the transmitter the car stops, but if i turn on the transmitter again the car drives away full blast for the little time the transmitter takes to boot.
Very weird issue. My receiver is afhds and the failsafe is set only from the receiver. The only failsafe setting i have on the transmitter is for afhds2
Could the problem be the IRangeX controller ?
Jun 20, 2020, 06:29 PM
Nobody can help ?
Discussion FS-GR3E - Throttle full when radio is booting biomecanoid Radios 2 Sep 29, 2020 09:52 AM
Discussion Any known issues with getting full throttle FS-iT4S RaisedByWolves FlySky 11 Apr 19, 2019 12:26 PM
Help! ESC booting then resetting when adding throttle Pilotw Multirotor Drone Power Systems 2 Dec 30, 2017 03:14 PM
Discussion Naze 32 throttle issue, Quad Flys off when past 50% throttle. Liamm FPV Talk 4 May 21, 2017 11:14 AM
Discussion HK310 throttle trigger doesn't work, when I press th. hold motor goes full throttle DutchMofo Electric Power Cars 10 Jul 20, 2016 02:40 PM
