ASHIL II Flight Simulation System
ASHIL II (AheadX Simulator Hardware In the Loop II) is a flight simulation system for UAV application.
The ASHIL II is lighter and smaller in size. Using the X-plane 11 simulator, ASHIL II is able to provide detailed and real effect flight simulation in a variety of scenarios such as flight simulation switched among worldwide airports, weather targeted flight training or flight failure emergency response simulation, etc.
ASHIL Flight Simulation System (4 min 3 sec)
ASHIL II supports both manual mode and auto flight. Normally, auto flight consists of route planning of surveying and inspection, parameter modification, pre-flight check and fully autonomous flight operation simulation. A Sbus port is reserved for linking a receiver, making manual mode possible.
ASHIL II requires no 220V power supply as the former version, it needs only a USB cable connecting to PC for power supply.
Both novice pilots and experienced professional pilots can improve their professional flying skill through different stages of flight training, building a solid foundation for their actual flight operations eventually.
Features:
  • Easy to use, giving you a quick start
  • No need of 220V power supply as the former version, ASHIL II only requires power supply from PC with a USB connected
  • Reserving a Sbus port for linking a receiver, which makes manual mode possible
  • All-model supported: fixed-wing, multi-rotor, VTOL(quad plane and tilt wing), helicopter and other customized aircraft
  • Good match with Space V3 Ground Control Station, effective ground station operation practice
  • Manual flight and route-planning auto flight
  • Detailed simulative flight scenarios switched between worldwide airports
  • Different weather scenario simulation, weather targeted flight training, supporting random weather patterns
  • Common flight failure (flameout, GNSS loss, rudder failure and propeller break, etc.) response simulation, emergency flight training
Applications:
  • UAV system integrator - flight verification, product model matching and ground station operation training
  • UAV training organization - ground control station operation course
  • UAV end user - ground station operational flight training and operational mission simulation flight practice
  • Univrsities and scientific research institutions - early simulation flight verification and flight control algorithm development verification
  • Defense applications - aircraft carrier, military UAV tracking flight and mission simulation
  • Weapon development - the flight and precision strike simulation of UAV airborne weapons or payloads
Your Purchase Includes:
  • 1x ASHIL II Flight Simulation System
  • 2x Micro USB-to-USB Cable
Learn More
For pricing and more info go here.
Help! Ambrosia RC aero chopper flight simulation system Luft 1 Simulators 3 Mar 02, 2015 03:43 AM
Cool Some viewpoints about Joystick Simulative Flight System AEORC Radios 2 Apr 26, 2010 02:03 AM
Discussion digital servos,R/C system,and flight simulator kaelyn_yang Russia 0 Dec 06, 2009 09:46 PM
Discussion Ambrosia RC Aerochopper Flight Simulation System franknieto Electric Heli Talk 0 Jan 24, 2009 06:51 PM
