FMS ASW-17 EP Glider
If you are looking for an inexpensive scale foam electric sailplane, then check out the FMS ASW-17 sold by Horizon Hobby.
2.5M Foamy ASW-17 from FMS
If you are looking for an inexpensive scale foam electric sailplane, then check out the FMS ASW-17 sold by Horizon Hobby. The Price is $269.99 on pre-order with shipments expected in about a month. For that money, you get the airframe, pre-installed servos and the motor and ESC. The motor is the Predator 3541-750kv with a Hobbywing 40A ESC. You'll need to provide your own receiver and a 4S 22000-2600mAH lipo battery.
The FMS ASW-17 features a two-piece wing, functional flaps, durable EPO construction, folding prop and no-glue assembly. The wings and stabilizers are designed to snap-in place for easy assembly. It takes less than 3 minutes to get it put together. To stiffen up the wings they have carbon spars inside so feel free to pull some loops. There's an aluminum spar joiner that hold the dihedral at the same angle as the full size glider. It's a nice looking plane at an affordable price.
Specifications:
  • Wing Area: 779.5 sq in (50.3 sq dm)
  • Wing Loading: 0.09 oz sq/in (45.7 g sq/dm)
  • Wingspan: 98.4 in (2500mm),98.4 in (2500mm)
  • Flying Weight: 5.2lbs (2350g) approximately
  • Approximate Assembly Time: Less than 1 Hour
  • Approximate Flight Time: 10 minutes
  • CG (Center of Gravity): 2.7 - 3.1" (70 - 80mm) back from leading edge of wing measured at the fuselage
  • Landing Gear: Monowheel with tail skid
  • Length: 54.7 in (139mm)
  • Material: EPO foam
  • Minimum Required Radio: 6-channel
  • Propeller Size: 13.5x6 fold away
  • Recommended Motor Battery: 4S LiPo 14.8V 35C 2200-2600mAh w/XT60 connector (sold separately)
  • Servos: Two 9g, four 17g
Check out the FMS ASW-17 EP Glider Here
Jun 03, 2020, 12:34 PM
Mesa AZ, it's a dry heat!
Error
The stated wing loading is wrong, obviously. it should be 15.37 oz/sq.ft ( quick way to translate g/sqM to oz/sqtf is to divide by 3).
Still a little too heavy for thermal soaring I think.
It will probably be good as a slope soarer with a motor "save" feature!
Why can someone not produce a foam floater with a wing loading in single digits?
Just a thought.
Iain
Jun 03, 2020, 12:38 PM
About 1.5 lbs heavier than an MPX Cularis, which is similar size. Bit chunky, but may do well on the slope. Good to see new releases at least.
Jun 03, 2020, 01:00 PM
JPJI's Avatar
Or you could just buy a volantex ASW28, same size, less than half the price and looks nicer in my opinion....
https://uk.banggood.com/Volantex-ASW...r_warehouse=CN
Some aerobatics with my ASW 28 2.6M glider (4 min 12 sec)
Video by Adam Fisher
Jun 03, 2020, 01:24 PM
They are both a waste of time, the Volantex 28 has ANHEDRAL which is bizarre, and the FMS 17 is way too small to thermal, high wing loading at 100 inches? Why bother. Buy a Radian.
Latest blog entry: Testing the blog page
Jun 03, 2020, 01:32 PM
JPJI's Avatar
The ASW-28 does not have anhedral. It has a straight wing which flexes in flight giving dihedral. Radian is overpriced and discontinued.
Its all down to personal preference I suppose.
Jun 03, 2020, 02:41 PM
CR5
CR5
Just bought a Volantex ASW-28, somehow I got hooked on gliders recently. This will be #4 in the hangar
This new ASW-17 looks nice but knowing HH it will cost at least double what I just paid.
Plus FMS really ticked me off after purchasing the 64mm F-18 and getting zero customer support when I had issues with it.
Jun 03, 2020, 03:10 PM
JPJI's Avatar
That's typical of my experience of HH - double the price of anywhere else and zero customer support.
Jun 04, 2020, 03:19 AM
saltomortale's Avatar
Nice sailplane, but it's far from being a scale plane !
Jun 04, 2020, 10:58 AM
Official Boat Bum
Eddie P's Avatar
This looks like a great value for a sport flyer interested in gliders. It's certainly not for the purist. But foam would not, in the first place, likely be considered by a purist to begin with.
I'd be interested in flying this and also the 3M Fox. This looks like it would be a great all around model for a sailplane enthusiast / slope pilot / sport pilot. All in once fun flyer capable of flying when the lift is just so-so or the slopes are dead or the club field is not hopping with fast sport /jet / pattern action.
Jun 04, 2020, 05:41 PM
Crazy Canuck
NEWBEFLYER's Avatar
https://www.youtube.com/watch?v=ZvFYnlwkI6c
I like your glider "Retriever" system LOL
Jun 04, 2020, 09:15 PM
rrg
rrg
rrg's Avatar
Not to sure about that inexpensive part....
Jun 05, 2020, 07:54 AM
rfd
rfd
AMA 51668
rfd's Avatar
The ASW-17 may fly well, but with such a high wing loading it would be hard pressed for any decent duration. The defunct Radian or Calypso V2 are among the the best foam gliders ever produced.
IMHO, the best performing value for an ARF e-glider is still the Vista BL from TH, $130. Yes, it's a 2 meter RET and does require a pair of servos, an RX and an 1800 3s battery. It's NOT foam, which for a glider I consider is generally a good thing, but it sure IS a true sailplane that will float and thermal quite well with 8oz or less wing loading. YMMV.
Jun 05, 2020, 10:33 AM
rrg
rrg
rrg's Avatar
Yep I have one^^^and love it! You have to tell it when to come down...
Jun 06, 2020, 04:00 AM
ConEx's Avatar
Wondering seeing the Chocofly logo. So ist this FMS plane in fact a semiscale copy of a scale model?
http://www.chocofly.com
New Product FMS 2500mm ASW-17 Bajora Electric Sailplanes 173 Dec 16, 2020 07:46 AM
Cool Robbe ASW 17 Royal from the 90s Kenny Sharp Scale Sailplanes 15 Sep 03, 2019 07:43 AM
Discussion Robbe ASW 17 Royale 4 metre vic1958 Scale Sailplanes 3 Oct 23, 2018 05:49 PM
Discussion HobbyKing PT-17 vs FMS PT-17 vs EFlite PT-17 15e seeking opinions and experiance. loserdave Electric Plane Talk 5 Apr 13, 2016 03:37 PM
Help! Old Robbe ASW 17 Royale vic1958 Scale Sailplanes 4 Oct 12, 2015 05:45 PM
