Jun 07, 2020, 08:37 AM
LongRange_UAV_4G
The power to fly is effected by a number of factors and probably the most important is aerodynamic efficiency of the air frame in converting thrust into lift.
The next issue is the speed is has to fly at to generate the required lift. The speed required is proportional to the wing loading.
So 'smaller' at a given weight will require more power to fly (it has to fly faster) than 'bigger' at the same weight.
To answer you question about the power to fly a 500 g weight plane you do need the shape and size (area) of the wing.
A delta is not particularly efficient shape so if you can get your 500 g plane to have a wing area of close to 0.4 sq m it should be able to fly quite nicely with 100 W and have quite an aerobatic performance with 150 W.
Jun 12, 2020, 02:09 AM
weather issues here, working on it, will update you soon
Jun 12, 2020, 02:10 AM
Originally Posted by balsa or carbon
Looking forward to it !
Jun 12, 2020, 02:34 AM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Any progress on a build ?
Jun 12, 2020, 11:06 AM
i'm working on other projects too so i've parked it due to the weather for now, i imagine i'll be moving again in 1-2 days
Jun 13, 2020, 03:22 AM
how's this looking?
Jun 13, 2020, 03:00 PM
how's this looking?
That'll fly .
A couple of tips :
1) For slower docile flight , make the airframe as large as possible . A small airframe may be hard to handle for an inexperienced RC airplane flyer .
2) Make the prop slot only as big as it needs to be for the prop . A giant prop slot hole takes away wing area , and will also weaken the airframe ( more likely to break if it hits the ground nose-first ) .
Jun 13, 2020, 09:06 PM
That'll fly .
A couple of tips :
yes it seems like it will fly, can i fly it? that's a different question
it's very interesting how you can use hot glue for the hinges
Jun 13, 2020, 09:23 PM
If possible , show us a video when you try to fly it .
Jun 14, 2020, 08:43 AM
will do, i predict the score will be gravity 1 me 0
Jun 16, 2020, 09:29 PM
still blocked by weather here
Jun 17, 2020, 09:29 AM
haha, i just realized i can drop the test delta from my dji
Jun 17, 2020, 01:08 PM
Definitely want to see that video !
Jun 19, 2020, 05:10 AM
first day got good weather and my dog was sick, maybe get lucky tomorrow
Jun 19, 2020, 01:25 PM
it flew, well!
i had an involuntary tree landing but otherwise flew very well
hopefully got video
will update soon
Question Is it tail heavy, nose heavy, or what? djacob7 Foamies (Scratchbuilt) 9 Jun 27, 2018 04:18 PM
Discussion tail heavy, nose heavy or just on the mark? vil64 High Performance 11 May 23, 2013 09:23 PM
Question pica 1/8 Corsair kit tail or nose heavy? ululi1970 Fuel Warbirds 3 Feb 11, 2012 09:03 PM
Poll SU-26m; nose or tail heavy? jrb Micro Ready-to-Fly 6 Nov 18, 2009 08:59 PM
