Jun 04, 2020, 03:37 PM
oh, yeah sorry misread inches for degrees, so the sweep is 45deg on both
so smaller is faster, now it makes sense
Jun 04, 2020, 04:13 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Smaller is more agile : quicker rolls and loops . Larger is more docile : slower rolls and loops .
Top speed depends on the motor/prop/voltage , and airframe drag . A larger airframe will usually have more drag than a smaller airframe , if they are both the same design .
Jun 04, 2020, 09:54 PM
ok, i definitely want to do this but i'll wait until my new parts arrive, one week or so, i'll also test fly my modified first wing, for now that's delayed a little by weather and other things
Jun 04, 2020, 11:13 PM
these are the motors i'm getting
https://www.youtube.com/watch?v=pp69vawQcuw
oooooooh, my parts are in the country, so 1-2-3 days, cool
Jun 04, 2020, 11:45 PM
i think what i'm going to try and do is get a delta flying with a flight controller and gps on it, if that works maybe a vtol one with two motors
obviously i'll try a simple one first
Jun 05, 2020, 12:56 AM
Tiny high-kv quad motors are not ideal for an RC airplane , but that doesn't mean they won't work . Twin motors would definitely be better than just one .
Do you want to put a 6 axis flight controller on a delta for self-leveling , or just a 3 axis gyro for wind gusts & turbulence ?
I recommend waiting to put GPS on until after you have successfully flown several flights .
RC Groups member goldguy has built a delta with twin motors :
https://www.rcgroups.com/forums/show...9-The-UltraFly
Jun 05, 2020, 08:57 AM
i want to be able to program missions
thanks for all the info. much appreciated
Jun 05, 2020, 05:40 PM
i'll let you know when the parts arrive, that's the next step
that twin motor delta is cool, will be interesting to make a vtol one like that
Jun 05, 2020, 11:38 PM
i tried to fly my model, it's too heavy and under powered, it flies ok now, only slowly and towards the ground, i'm going to start again when my new parts arrive, with a much lighter delta
Jun 05, 2020, 11:56 PM
got any thoughts on power to weight?
if i make a 500g delta how much thrust do i need to keep it airborne?
Jun 06, 2020, 12:56 AM
What are all the motors do you have at the present time ?
Jun 06, 2020, 10:01 PM
here you go, the big one seems to give over 1kg of thrust and the smaller one about half that
Jun 06, 2020, 10:29 PM
I recommend making a large SSD , as lightweight as possible ..... and using the smaller motor . And use the lightest battery you have that will provide enough volts/amps for that motor .
Once you are comfortable flying the large SSD LOS , then make a smaller SSD for more speed and agility .
Once you are comfortable flying the smaller SSD LOS , then add all the FC , GPS , RTH , WayPoint , etc. that you want .
And make sure you follow all the rules , regulations and laws ..... for the place where you will be flying .
Jun 06, 2020, 11:08 PM
hi, just found a sticker on another identical motor to the small one KV1450
thanks for all the advice, super appreciated
i'm currently waiting for a much smaller battery, i'll keep you updated on my progress
cheers
Jun 07, 2020, 12:10 AM
cheers
Looking forward to it !
Question Is it tail heavy, nose heavy, or what? djacob7 Foamies (Scratchbuilt) 9 Jun 27, 2018 04:18 PM
Discussion tail heavy, nose heavy or just on the mark? vil64 High Performance 11 May 23, 2013 09:23 PM
Question pica 1/8 Corsair kit tail or nose heavy? ululi1970 Fuel Warbirds 3 Feb 11, 2012 09:03 PM
Poll SU-26m; nose or tail heavy? jrb Micro Ready-to-Fly 6 Nov 18, 2009 08:59 PM
