Jun 03, 2020, 11:54 AM
Originally Posted by goldguy
Doesn't matter. The law is the law.
Take it up with the FAA.
of course it matters
Jun 03, 2020, 11:56 AM
Originally Posted by balsa or carbon
I've put very basic gyros on scratch built planes a few times , and I've had two store bought planes with SAFE/AS3X . I have no experience with any advanced FC systems involving GPS etc .
For purposes of RC flying practice , a simple 3 channel plane such as the Smart Dart XS is all you need . A 3 channel plane with a high wing that has dihedral/polyhedral is inherently stable and doesn't need FC . And if you build it with low wing loading it will be slow flying . Slow flight gives you time to think , time to react , and time to correct a mistake .
Here is a video of a plane I've built with a high-wing/dihedral & very low wing loading , you can see how it would be easy for anyone to fly :
https://www.youtube.com/watch?v=P2Xyjy3fcpE
that's cool, thanks for that
Jun 03, 2020, 12:17 PM
another question, let's say with a maximum 1500mm wing span which design will give you the longest range?
Jun 03, 2020, 01:08 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
I've never attempted long range flight , but probably a sailplane/glider type plane would be best . Very streamlined for low drag , and very lightweight so the motor doesn't have to work hard . And in the right conditions ( ridge lift and/or thermals ) , a sailplane can fly for a long time without using the motor at all .
RC Groups member boa2110 scratch builds sailplane/gliders often , he may be able to help you if you want to build one . Be aware that scratch building a sailplane involves advanced/experienced building techniques , and you may have more success with a store-bought sailplane . Here is one example of a store bought sailplane/glider : https://hobbyking.com/en_us/hking-ez...-1500-pnp.html
Here is a video of one of boa2110's sailplanes :
10ft foam sailplane (2 min 18 sec)
Jun 03, 2020, 07:09 PM
https://www.youtube.com/watch?v=q9hHtcbpT4o
ok, cool, interesting, i also bought one of these:
https://www.banggood.com/Volantex-AS...r_warehouse=CN
too scared to fly it after damaging my other one, but came to the conclusion a sailplane might be the way to go
Jun 03, 2020, 07:36 PM
Building a cheap foam home made plane is good for flying practice , then fly your more expensive planes when you feel confident .
If you need assistance building a Smart Dart XS or other home made plane , I'll be glad to help .
Jun 03, 2020, 10:02 PM
i've just modified my existing plane rather than start fresh, if that does not fly well enough i'll build a delta, also do you know anything about flying wings?
Jun 03, 2020, 10:23 PM
Updated wing design
These are the changes I made
Jun 03, 2020, 10:33 PM
The Simplest Simple Delta ( SSD ) of posts #5 & #6 is technically a flying wing ( tail-less aircraft ) , and I've built quite a few SSD's . The 30" version is more agile , the 40" version is more docile .... so I recommend building the 40" SSD if you're just learning to fly .
The SSD is a low Aspect Ratio flying wing ( shorter wingspan relative to longer wing chord ) . High Aspect Ratio flying wings ( longer wingspan relative to shorter wing chord ) are more common and more popular , but can be difficult to set up & tune for pitch .... due to the shorter chord . You have to get just the right combination of CG , reflex , thrust angle , etc .
Here is my 40" Simplest Simple Delta :
Giant simple delta (2 min 0 sec)
Jun 03, 2020, 10:36 PM
Test fly tomorrow ?
Video if possible !
Jun 03, 2020, 10:44 PM
Test fly tomorrow ?
Video if possible !
yes, well it's my morning here so hopefully in the next few hours, i'll post a video for sure
Jun 03, 2020, 10:54 PM
youtube.com/watch?v=CP-He0NJ_SY
i've got one of these on the way so i want something to best simulate that, ideas?
once i can fly it i plan to add:
1. flight controller & gps
2. 4g fpv
3. 4g mission planner
4. some kind of gimbal hd zoom camera
Jun 04, 2020, 12:30 AM
2. 4g fpv
Possibly a good plan :
1) learn to walk with a 40" SSD .
2) learn to run with a 30" SSD .
3) when you can comfortably fly the 30" SSD at high speeds , then fly your FPV racing wing .
Here is my 30" SSD flying , you can see that it's quicker and more agile than the 40" SSD :
Simplest simple delta (1 min 20 sec)
Jun 04, 2020, 01:29 AM
does that have any stabilization?
also what's the 30 deg, the center line to leading edge?
also also in 5-10 days i've got a bunch of parts arriving including esc, motor and battery ideal for a small fast delta
Jun 04, 2020, 12:57 PM
No stabilization on the 30" SSD in the video . I recommend building a 40" SSD first ( learning to walk ) , then build a 30" SSD ( learning to run ) .
The leading edge sweep is 45º , if that's what you're asking . All the info for building an SSD is in this thread :
https://www.rcgroups.com/forums/show...h-simple-plans
If you live in a country where foam board sizes are designated A1 , A2 , A3 , etc ...... the size you'll need is A1 .
Question Is it tail heavy, nose heavy, or what? djacob7 Foamies (Scratchbuilt) 9 Jun 27, 2018 04:18 PM
Discussion tail heavy, nose heavy or just on the mark? vil64 High Performance 11 May 23, 2013 09:23 PM
Question pica 1/8 Corsair kit tail or nose heavy? ululi1970 Fuel Warbirds 3 Feb 11, 2012 09:03 PM
Poll SU-26m; nose or tail heavy? jrb Micro Ready-to-Fly 6 Nov 18, 2009 08:59 PM
