Apr 21, 2005, 09:57 PM
evolekim's Avatar
New cc controller software (improved govenor)
I just donwloaded the latest firmware from castle ver 1.12. They have changed the rpm ranges to allow for high pole count motors. I have a cc25 and a Mega and can't get my motor to start with any gov setting or atv points. I assume i want high gov since the mega is a 6 pole motor. Hope others have more luck than I.
Apr 22, 2005, 07:48 AM
2 Turbos...Nope 1 Big one
skeppley's Avatar
I downloaded last night too, but havent tried it yet. Still running 1.10, since the 1.11 wasnt so great, i was kinda of scared to hop right into the 1.12 without some other opinions first. Maybe i'll give it a go later, if no one else reports on it.
Apr 22, 2005, 11:37 AM
evolekim's Avatar
Well I finally got my controller to arm, It took maximum atv as well as full trim to get it to arm. The good news is that the gov now seems to work well. I am getting about 2150RPM headspeed on my Rex with a Mega 16/15/3 and 2100 3s with a throttle curve of 0,35,35,35,35
Apr 22, 2005, 02:36 PM
Old new guy
TheX's Avatar
That's good news, I'll have to give it a try this wekend.
Apr 22, 2005, 04:25 PM
35% on the throttle seems a bit low. What happens when you use low governor instead? Can you get the throttle higher? Or does that governor setting just not work?
Apr 22, 2005, 04:31 PM
Old new guy
TheX's Avatar
35% on the throttle means nothing as far as the actual settings are concerned. 35% on the trans. may be 80% on the speed controller.
Apr 22, 2005, 04:38 PM
Lynxman's Avatar
I had to increase the endpoints of my throttle channel considerably in order for the ESC to arm, and That's why it won't start. I set it to 130 bottom / 110 full throttle stick which calibrated the range to the ESC range.
I tried the new firmware in my little flybarless sub-micro and it actually works. YAY! the heli has a 12 pole CD-ROM based outrunner and previously it wouldn't reach a useable rpm in governor mode.
Apr 22, 2005, 04:49 PM
Chesapeake Bay RC Club
Gary Hoorn's Avatar
Anyone know how many poles the Himax 2815 3000 motor has? Mine is working fine but as I have the Link I was thinking of trying the new software.
Gary
Apr 22, 2005, 04:52 PM
I just checked out the cc web site. They changed the RPM ranges of the two modes to have a lot wider range. So what might have been 80% in low mode in now 35% in high mode.
The increased range means better support for lots of poles.
Governor low has been working well for me for a while but I'll probably have to switch to high and lower the throttle setting too. Or, just not update the software.
Apr 22, 2005, 06:08 PM
Our Daddy and Heli Junkie
Fred Bronk's Avatar
I just setup a larger heli with the 80 and it worked great.
Solid in low gov on 4s with a smooth spoolup.
Apr 23, 2005, 11:32 AM
Mheeli's Avatar
I just tried it on the Trex with the Align motor that came with it. It worked great! (It did not work with the previous firmware)
My TH curve is 65% which gives me around 2000 RPM. I did a ground testing and the RPM seemed very stable throughout pitch range.
Apr 24, 2005, 01:16 AM
Stupid Newbie
So what's the verdict? I'm running it using fixed throttle with a 35 and a 400DH. I'd like to see what the other modes can do since now they do nothing. Maybe I'll just flash it anyways.
New CC Controller? unbalanced prop Power Systems 7 Apr 15, 2005 09:03 AM
FS: CC Phoenix 10 new with latest software $40.00 shipped dawnron1 Aircraft - Electric - Airplanes (FS/W) 2 Apr 14, 2005 09:09 AM
New CC Phoenix 35 :( still getting hot? Corona rspiegel Electric Heli Talk 14 Apr 07, 2003 08:20 PM
?New Orbit V2 Software Questions? vkmaynard Batteries and Chargers 7 Feb 25, 2003 11:32 PM
I need a new a new speed controller crafty1 Sport Planes 1 Feb 20, 2003 06:32 AM
