This thread is privately moderated by kopterheld, who may elect to delete unwanted replies.
May 24, 2020, 06:02 PM
Mini-Review
BetaFPV ET5 DJI Vista 5 inch 237g
A 5 inch toothpick Quad ET5 with Caddx Vista module, weighs 160 grams and with 650mAh 4S Lipo 237g. The quad is quiet, fast enough, agile and the lightest 5 inch quad you can fly with DJI goggles. Everything built from BetaFPV components.
Video 1 - BetaFPV ET5 DJI Vista 5 inch 237g first flight (EN - subtitles)
BetaFPV ET5 DJI Vista 5 inch 237g (4 min 42 sec)
159 grams with Caddx Vista module and CrossFire Nano receiver
Or with the 3S 850mAh Tattu R-Line battery you can fly over 6 minutes.
1505 motors are perfect for the light 5 inch frame to fly under 250g. More strength would be better, but that's fun.
I fly here with the DJI goggles, the ET5 with Vista module, CrossFire Nano, DJI FPV goggles and the compact Taranis X9 Lite with a Crossfire module on the back.
Flying 5 inches is fun with only 237 grams. The footage of the DJI Digital FPV system is great and that is completely sufficient even with 25mW video transmitter power. I use Crossfire for two reasons. I want to have a better range with the control system without failsafe even if the DJI digital video should stop. And I want to continue to be able to fly the small TinyWhoop analog.
Shopping list for ET5 DJI Edition:
1. ET5 Frame Platte
2. Canopy for Mini Camera V3
The Vista hood is the best, light and very strong molded plastic.
3. Caddx Vista HD VTX Rush Tank Antenna
4. 4x 1505 3600KV Brushless Motor 4S
5. BetaFPV Toothpick F4 2-4S AIO 20A V3.0
6. HQprop Durable T5X3 5030 2 blade Propeller (Banggood)
Other propellers with a higher pitch or more than 3 blades should not be used with the small motors, as they only use too much electricity and do not fly better.
7. Tattu R-Line 650mAh 4S 95C Lipo (Banggood)
Gift vouchers - http://bit.ly/BetaFPVgc,
which I buy with a 5% coupon: GiftCard first at BetaFPV.
Here you get a 5% discount on all parts at BetaFPV
http://bit.ly/KHBetaFPV
Caddx Vista Module pins
For the Vista module I use RX9, TX9 solder pins on the FC which are controlled via soft serial. Therefore soft serial has to stay on and additionally the soft serial setting has to be adjusted under CLI.
Here Softserial 11 is adapted for DJI, since originally under Betaflight both pins run as TX, i.e. Serial RX and TX on B03
resource SERIAL_RX 11 B10
My first configuration 2020-05-23
Betaflight 4.2 with activated bidirectional DSHOT thus the RPM filters are active. Here I sit JazzMaverick blheli_S RPM Firmware 16.9 mit 48kHz ein. ( G_H_25_48_REV16_96_beta2.HEX )
Here is the complete DIFF ALL from Betaflight 4.2 rc2
The settings are not yet perfect.
# kopterheld 2020-05-23
# RPM an, with G_H_25_48_REV16_96_beta2.HEX
# diff all
# version
# Betaflight / STM32F411 (S411) 4.2.0 May 13 2020 / 14:27:01 (6aeac3caa) MSP API: 1.43
# config: manufacturer_id: BEFH, board_name: BETAFPVF411, version: 5e160c8b, date: 2019-12-11T10:26:31Z
# start the command batch
batch start
# reset configuration to default settings
defaults nosave
board_name BETAFPVF411
manufacturer_id BEFH
mcu_id 004e00643439511038313437
signature
# name: ET5 DJI
# resources
# beeper
beeper -GYRO_CALIBRATED
beeper -RX_LOST_LANDING
beeper -DISARMING
beeper -ARMING
beeper -ARMING_GPS_FIX
beeper -BAT_CRIT_LOW
beeper -BAT_LOW
beeper -GPS_STATUS
beeper -ACC_CALIBRATION
beeper -ACC_CALIBRATION_FAIL
beeper -READY_BEEP
beeper -DISARM_REPEAT
beeper -ARMED
beeper -SYSTEM_INIT
beeper -ON_USB
beeper -BLACKBOX_ERASE
beeper -CRASH_FLIP
beeper -CAM_CONNECTION_OPEN
beeper -CAM_CONNECTION_CLOSE
beeper -RC_SMOOTHING_INIT_FAIL
# beacon
beacon RX_LOST
beacon RX_SET
# map
map TAER1234
# serial
serial 0 0 115200 57600 0 115200
serial 1 64 115200 57600 0 115200
serial 30 1 115200 57600 0 115200
# aux
aux 0 0 0 1700 2100 0 0
aux 1 1 1 900 1300 0 0
aux 2 2 1 1300 1700 0 0
aux 3 13 2 1700 2100 0 0
aux 4 35 2 1300 1700 0 0
# rxrange
rxrange 0 988 2011
rxrange 1 988 2011
rxrange 2 988 2011
rxrange 3 988 2011
# master
set gyro_lowpass2_hz = 325
set dyn_notch_width_percent = 0
set dyn_notch_q = 250
set dyn_notch_min_hz = 70
set dyn_notch_max_hz = 350
set dyn_lpf_gyro_min_hz = 260
set dyn_lpf_gyro_max_hz = 650
set acc_calibration = -83,103,-227,1
set min_check = 1010
set max_check = 1990
set rssi_channel = 12
set rc_smoothing_auto_smoothness = 20
set serialrx_provider = CRSF
set blackbox_device = NONE
set dshot_idle_value = 400
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT300
set motor_poles = 12
set vbat_max_cell_voltage = 440
set beeper_dshot_beacon_tone = 5
set yaw_motors_reversed = ON
set small_angle = 180
set osd_vbat_pos = 2400
set osd_rssi_pos = 2272
set osd_tim_2_pos = 2423
set osd_flymode_pos = 247
set osd_throttle_pos = 2368
set osd_vtx_channel_pos = 0
set osd_crosshairs_pos = 2253
set osd_current_pos = 2390
set osd_craft_name_pos = 2379
set name = ET5 DJI
profile 0
# profile 0
set dyn_lpf_dterm_min_hz = 91
set dyn_lpf_dterm_max_hz = 221
set dyn_lpf_dterm_curve_expo = 7
set dterm_lowpass2_hz = 195
set vbat_sag_compensation = 100
set feedforward_transition = 40
set iterm_relax_cutoff = 10
set yaw_lowpass_hz = 70
set throttle_boost_cutoff = 10
set p_pitch = 55
set d_pitch = 46
set f_pitch = 124
set p_roll = 50
set d_roll = 42
set f_roll = 117
set p_yaw = 54
set f_yaw = 117
set d_min_roll = 28
set d_min_pitch = 30
set ff_interpolate_sp = AVERAGED_3
set ff_spike_limit = 55
set ff_smooth_factor = 40
set ff_boost = 0
profile 1
profile 2
# restore original profile selection
profile 0
rateprofile 0
# rateprofile 0
set pitch_rc_rate = 101
rateprofile 1
rateprofile 2
rateprofile 3
rateprofile 4
rateprofile 5
# restore original rateprofile selection
rateprofile 0
# save configuration
save
More pictures here - http://kopterheld.tv/2020/05/24/betafpv-et5-dji-vista/
My Kopterheld Coupons on Blog, Telegram or FB:
https://kopterheld.tv/
https://t.me/KopterHeld
FB - http://bit.ly/KhFaceBo
My Equipment:
DJI Digital FPV System - https://www.banggood.com/custlink/mGvK0KF1Em
Fatshark Dominator HDO2 - https://www.banggood.com/custlink/KmGKeeY4pN
ImmersionRC RapidFIRE - https://www.banggood.com/custlink/vm3v6vafP1
Taranis X9D Plus SE 2019 - https://www.banggood.com/custlink/v3mKeGLLp6
Jumper 4IN1 Multimodule - https://www.banggood.com/custlink/vGvGNp7s07
FrSky R-XSR - https://www.banggood.com/custlink/DGvDgKOu8B
CADDX Ratel - https://www.banggood.com/custlink/KKKm6mLf9Q
Youtube – https://www.youtube.com/kopterheld
Blog – https://kopterheld.tv/
RCGroups – https://goo.gl/JYP87D
Telegram - https://t.me/KopterHeld
Instagram - https://instagram.com/kopterheld
Twitter - https://twitter.com/kopterheld
Article Racer X FPV “Extraterrestrial TWIG 5” ET5 Jason Cole Multirotor Drone Talk 1 Feb 04, 2020 05:55 AM
Question 5" quad with GoPro: DJI Air Unit or Caddx Vista ? furvent FPV Equipment 0 Jan 24, 2020 10:35 AM
