This thread is privately moderated by txshan130, who may elect to delete unwanted replies.
May 23, 2020, 12:16 PM
Trader Rating: 639
txshan130's Avatar
$35.00 USD
Buyer pays shipping
Sold
SmartFly TurboReg
SmartFly TurboReg for sale in great shape. Specs below
The Smart-Fly TurboReg is ideal for aircraft with engines larger 100cc size. All power input and output connectors are Deans Ultra Plugs to handle the high currents the TurboReg is capable of. The unit is will handle 17.5A continuous current but can handle peak currents in excess of 35A. The unit has dual battery inputs for redundancy and has a built-in BatShare to balance battery draw and prevent a bad battery pack from affect a good pack. It can be used with any battery pack who's maximum charge voltage is 8.4V or less. The minimum input to output voltage differential is 0.45V. For instance, if you set the output voltage to 6.0V with a 5-cell NiCd/NiMH pack, when the pack falls below 6.45V the output voltage will start to drop accordingly. When the pack is 6.0V the output will be about 5.55V. The regulator has a minimum input voltage of 3.0V. It features adjustable voltage output from approximately 5.2V to 7.4V. It supports the use of an optional failsafe switch.
Features:
Built-in BatShare
Deans Ultra Plugs In & Out
Input to Output minimum differential is 0.45V
Adjustable output voltage, ~5.2V to 7.4V
17.5A continuous, 35A peaks ( 8.4 volts in & 6.0 volts out)
Optional Failsafe Switch & Charge Package Available
Lightweight: 2.0 oz
Small size: 2-3/4 x 2-1/4 inches
CAUTION: When the regulator is operated with the optional failsafe-switch it presents a slight load to your battery even when off. This load is 0.4mAH or about 10mA out of your pack for each 24-hour period. You should disconnect the battery if you the plane will be sitting for more than a couple days.
$35 shipped anywhere conus
Sold Smartfly TurboReg sunkidus Aircraft - General - Radio Equipment (FS/W) 0 Oct 13, 2016 08:34 PM
Sold Smart-Fly PowerExpander EQ10/TurboReg/2s 5400LIPOs bobzilla Aircraft - General - Radio Equipment (FS/W) 0 Jul 06, 2016 07:03 AM
Sold Smart-Fly (Power Expander EQ10 & TurboReg) Sabercat757575 Aircraft - General - Radio Equipment (FS/W) 1 Feb 16, 2016 08:11 AM
Sold Spektrum 9100 rec & smart fly power expander & turboreg propnut1 Aircraft - General - Radio Equipment (FS/W) 1 Jan 18, 2015 08:12 PM
Sold Smart-Fly Power Expander Futaba, TurboReg and Flag Switch antoniomendes Aircraft - Fuel - Engines and Accessories (FS/W) 0 Jan 02, 2009 03:35 PM
