May 20, 2020, 06:36 AM
iFly SL
Build Log
3D printed twin 21mm EDF F-15
I have learned a lot the last couple of weeks as I built my first two 3D printed micro jets: a sportjet and a FAM IAe 48.
https://www.rcgroups.com/forums/show...-Sport-Jet-EDF
https://www.rcgroups.com/forums/show...Micro-Twin-EDF
I am having fun, so I am starting yet another 3D printed jet; this time a 21mm EDF twin F-15. Now, I know that I am being very ambitious here as this jet is a bit more complex and I will probably need a few iterations to get it right. My biggest worry is fan performance due to the long ducts and weight. The EDF system used is the same as the IAe 48 but this plane will need a minimum of 4 servos so I will be using the same receiver as on the sportjet with four micro servos.
This F-15 is based on an earlier design from many years ago for EPO. With two 56mm Hyperflows on 4S the original flew very well, with a top speed of 109mph. This one will be much smaller, with a wingspan of approximately 290mm (11.5") and it will surely not fly that fast! Anyway, as I said, this one is an ambitious project, but I hope to work out all the kinks and end up with a nice flying F-15. Wish me luck!
Sportjet
May 20, 2020, 09:37 AM
Good Luck!!!
May 20, 2020, 01:07 PM
How high will it go?
antslake's Avatar
LW PLA opens up so many doors. Where do you purchase 21mm fans.
May 20, 2020, 05:35 PM
yank and bank!!
That is truly impressive.
Care to share the STL's?
May 21, 2020, 02:41 AM
iFly SL
Hi Antslake
The fan is my own design and you can find it here as a complete unit or separately.
https://www.shapeways.com/product/VV...li=marketplace
Sportjet
May 21, 2020, 02:44 AM
iFly SL
Thank you!
We are a long way away from that....if it works, I may post the files somewhere, but first, I need to work out all the kinks and test fly it.
Sportjet
May 21, 2020, 06:52 AM
iFly SL
I have now printed the aft half of the fuse and test fitted the fans.
The fan fit is good, but the parts feel a bit heavy to me as they are 15.5g for the front half and 25.2g for the aft half. They feel plenty strong, so I think that I may be able to adjust some print settings and lower that weight a bit. even if only a 20% or so, that is almost 10g in total. I will also print the wings using the same settings to see if on this plane it makes sense to go with the printed version instead of making them with wood, which is what I did on the other planes so far.
Sportjet
May 22, 2020, 01:58 AM
iFly SL
Success!
After a few tweaks to the slicer settings the new parts are significantly lighter than the first ones yet they still feel strong enough for flying. I've gone from 40.5g for the fuse parts to 21.7g. Almost a 50% reduction!
Sportjet
Build Log 3D Printed IAe 48 Micro Twin EDF sportjet Micro EDF Jets and Power Systems 21 Today 03:43 AM
Discussion 3D printed 120mm EDF - 3D printed 1:6,5 scale L-39 Lynxman Large EDF Jets 1774 May 01, 2020 02:33 PM
Build Log 21mm EDF twin sportjet Micro EDF Jets and Power Systems 7 Nov 24, 2016 10:37 AM
Build Log F-Sweep XL KFm4 64mm EDF /w 3D printed EDF housing (64mm EDF housing installed) Arxangel Foamies (Scratchbuilt) 1 Jul 30, 2013 03:30 PM
Question How About A Edf Twin F-15 Kit ??? FCBrosius Electric Ducted Fan Jet Talk 21 Nov 17, 2005 11:36 AM
