More Gator-RC Plane Special Pricing!
Check out these planes from Gator-RC for special pricing during our Virtual Joe Nall event!
Gator-RC Show Deals!
We are very happy you stopped our Joe Nall virtual booth.  We have some exciting promotions!
We are happy to offer you 10% of select Seagull Model airplanes. You can use NALL10 at the checkout to claim.
Supermarine Seafire
  • SEAFIRE accurate color scheme
  • Full Aerobatic Fight Capabilities
  • High-Quality Balsa and balsa Plywood Offer Lightweight, State-of-the-art Construction
  • Accurate Scale Outline and Appearance, Including Tail Surfaces
  • One Piece Wing Make for Easy Assembly and Disassembly, As Well As Easy Transport To And From The Flying Field
  • The Factory-Applied Oracover Covering Trim Scheme Captures the Accurate Colors
  • Highly Detailed Cockpit and Painted Fiberglass Cowl…
  • Hand Painted Pilot
  • Mechanical Retractable Landing Gear
  • Extensive Hardware Package Included
  • Wingspan: 64.6 in(164cm)
  • Wing area: 759.5 sq.in (49 sq.dm)
  • Weight : 8.8 lbs(4 kg)
  • Length: 50.4 in(128 cm)
  • Engine : .75 - .91 2-stroke, .91 - 1.20 4-stroke, or equivalent brushless outrunner
  • Radio: 6 channels with 8 digital servos.
  • Flying skill level: Advanced
LINK - https://gator-rc.com/seagull-model-s...e-fly-navy-arf
Christen Husky (optional floats available)
  • High-quality balsa and balsa plywood, these make lightweight construction
  • Accurate scale outline and appearance
  • Pilot, pilot seat, and instrument panel decal included increasing scale appearance
  • Two-piece, plug-in wings with aluminum tube joiner to allow convenient transport/storage
  • Quick connect/disconnect wing struts simplify field assembly and transport/storage
  • Striking red, white and blue color scheme finished with genuine Oracover film covering.
  • Adjustable EP motor box included for easy electric motor power options
  • Functional flaps for enhanced flight characteristics and realism
  • Fiberglass control horns are included for a cleaner installation
  • Painted fiberglass cowling and wheel pants match Oracover film covering nicely
  • Ready to accept scale floats (sold separately)
  • Designed for gasoline, glow or electric power.
  • All the necessary hardware included
  • Spinner included (2.25″)
  • Wingspan: 80.0 in (203.2 cm)
  • Wing area: 922.3 sq.in (59.5 sq.dm)
  • Approximate flying weight: 8.8-10.3 lbs (4-4.67 kg)
  • Length: 50 in (1270 mm)
  • Recommended engine size: .61-.90 2-stroke, .90-1.20 4-stroke or gas/electric equivalent
LINK - https://gator-rc.com/airplanes/warbi...sten-husky-arf
Westland Lysander
  • Lightweight, high-quality balsa and plywood construction.
  • Eye-catching scale colour scheme.
  • Covered in genuine matt finish Oracover film.
  • Factory painted fiberglass engine cowl and wheel spats.
  • Detailed cockpit with a lightweight painted pilot figure.
  • Forward cockpit hatch for easy radio and flight battery access.
  • Superb flying characteristics.
  • Two-piece, plug-in wings simplify transportation and assembly.
  • Full hardware pack included for either glow or electric power.
  • Wingspan : 118in(299.7 cm)
  • Wing area: 1471 sq. in(94.9 sq dm)
  • Weight : 22 lbs(10 kg)
  • Length: 70.4 in(178.8cm)
  • Engine : 33-55cc (2 stroke), 40-60cc(4 stroke) recommended at 50cc.
  • Electric Conversion optional
  • Flying skill level: Intermediate/advanced
LINK - https://gator-rc.com/seagull-models-...matte-50cc-arf
DHC-2 Turbine Beaver (optional floats available)
  • High-quality balsa and balsa plywood, these make lightweight construction.
  • Accurate scale outline and appearance.
  • Functional scale cockpit doors with spring-loaded latches.
  • Corrugated scale surface detail on the flight controls.
  • Instrument panel and removable seat details included.
  • Two-piece, plug-in wings and stabilizers with aluminum tube joiner.
  • Quick connect/disconnect struts simplify field assembly.
  • Painted aluminum airfoil wing struts.
  • Scale color scheme finished with genuine Oracover film covering.
  • Adjustable EP motor box included.
  • Functional flaps for enhanced flight characteristics and realism.
  • Ready to accept scale floats (sold separately).
  • Designed for gasoline or glow or electric power.
  • All necessary hardware included.
  • Experience level Intermediate to advanced
  • Wingspan 203.2 cm / 80 in
  • Wing area 46.9 sq.dm / 727 sq.in
  • Overall length 143.5 cm / 56.5 in
  • Flying weight 5.2 kg / 11.5 lbs
  • Power system 20-30cc Gas
  • Radio 6 channels
  • Servos 7
  • Assembly time (approx.) 10 to 15 hours
LINK - https://gator-rc.com/seagull-dhc-2-turbine-beaver
Grumman F8F-2 Bearcat
  • Eye Catching color scheme. EASY TO SEE and SCALE YELLOW CONQUEST I RENO RACER Color Scheme
  • Covered in Genuine Oracover Film Covering. It makes airplane real scale
  • Factory Painted Fibreglass Engine Cowl
  • Detailled Cockpit with Light Weight Painted Pilot figure adds sporty, scale detail
  • Allows easy access to radio components and to the flight battery for those choosing an electric Power option
  • Includes durable fixed retract the landing gear
  • Superb flying characteristics, plus an accurate scale outline
  • All necessary hardware included for either glow or electric power system
  • Wingspan: 71.0 in (180.3 cm)
  • Wing Area: 1147.0 sp.in (74.0 dm˛)
  • Weight: 14.3 - 15.0 lbs (6.5 - 6.8 kg)
  • Length: 62.7 in (159.2 cm)
  • Engine/Motor size: 33 - 45cc
  • Servo: 8 channels 10 servos
LINK - https://gator-rc.com/airplanes/warbi...reno-racer-arf
Giant Zero A6M
  • Built-up, sheeted wood airframe is finished in flat Oracover film
  • Accurate Markings/Color scheme painstakingly recreated in the 81″ model
  • Compatible with a variety of powerplant options, allowing the consumer tho choose Glow, Gas or Electric Power
  • Impressive scale details including recessed instruments in a molded instrument panel, side panels, floor and seat provide increased realism.
  • This Japanese ZERO design from the original WWII aircraft and provides incredible, scale, warbird looks on the ground and in the air
  • Built into the fuselage is a large, magnetically-secured hatch that can be removed for quicker Lipo battery changes in electric setups
  • Full-function flaps are pre-hinged and provide scale appearance and realistic takeoffs and landings
  • Accurate scale outline makes it appealing to scale enthusiasts and includes a historical accurate color-scheme
  • A two-piece, plug-in wing aids in quick and easy assembly, convenient storage and transport to the flying field
  • Includes a detailed cockpit kit, replica radial engine, fiberglass wheel doors, fiberglass cowl, aluminum scale zero spinner, aluminum hub 4″ Main Wheels/Tires, upgraded fuel tank, center drop tank and more!
  • Optional Electric Landing Gear with Functional Off-Set Oleo Struts are Available - see listing below
  • TECHNICAL DETAILS:
  • Wingspan - 86″
  • Weight - 22 – 24 lbs
  • Wing Area - 1168.7 square inches
  • Length - 70.4″
  • Radio - 8 channel or greater recommended
  • Servos - 10 servos
  • Engine/Motor size - 50-60cc or equivalent electric motor with 160A-200A ESC, 12S LIPO, 24×10-25×12 Electric Prop
LINK - https://gator-rc.com/seagull-models-...-50-60cc-matte
JU-87 Stuka
  • Lightweight, high quality balsa and plywood construction.
  • Eye catching scale color scheme.
  • Detailed cockpit with lightweight painted pilot and rear gunner.
  • Removable cockpit hatch for easy radio and flight battery access.
  • Plug-in outer wing panels simplify transportation and field assembly.
  • Numerous scale details including bombs, sirens, machine gun and dive brakes.
  • Authentic semi-floating flaps and ailerons.
  • Crystal clear screw-on canopy molding.
  • Experience level intermediate / advanced
  • Wingspan: 228.6 cm / 90 in
  • Wing area: 85.7 sq.dm / 1328.7 sq.in
  • Overall length: 173.4 cm / 63.3 in
  • Flying weight: 8 kg / 17.6 lbs
  • Power system: 38-50 cc gasoline engine
  • Radio: 6 Channels
  • Servos: 7
LINK - https://gator-rc.com/ju-87-stuka-40-...seagull-models
See More!
At Gator-RC
May 24, 2020, 12:18 PM
Discount Code no longer needed!
We have made it easier to buy these models at a 10% discount. You no longer need the NALL10 code. We directly discounted everything on our site! Thank you to those of you that have already placed orders. We truly appreciate it.
Ashley
Gator-RC
Article Gator-RC Virtual Joe Nall Booth - Show Special!! Jim T. Graham Gator-RC Virtual Booth 1 May 24, 2020 12:17 PM
News FAA Special Rule for RC - More Responses Needed! Jim T. Graham Electric Plane Talk 58 Jul 24, 2014 12:33 PM
Cool EdgeRC MiniBOP Special Ezone Price (more than $20.00 off) 20 kits only!!!!! birdofprey Foamies (Kits) 1 Sep 24, 2004 08:54 PM
MiniBOP Parkflyer Special Ezone Price (more than $20.00 off) less than 20 kits left birdofprey Parkflyers 0 Sep 15, 2004 10:34 AM
