Gator-RC Lipos! Light packs with High Capacity!
Gator RC is excited to carry this new line...
5S, 5100mAh, HV 35C Lipo Battery, Ultra Light (Power Unlimited)
Next-generation Ultra Light (525 Grams) Power Unlimited HV Lipo 5S 5100 mAh 35C 19 Volt Watt Hours is 96.9. Free shipping lower 48 when combined with other items to make $99 in total.
These power packs are revolutionary technology resulting in the lightest pack on the market with the highest capacity!
  • New Pack - Less Weight
  • High Voltage cells can be charged to a maximum of 4.35 volts per cell.
  • Normal voltage cells are charged to 4.2 volts per cell.
  • Used by many top fliers at the USA Nationals they have a proven track record.
  • Amazing weight to performance ratio.Super Lightweight. 515 grams
  • Next generation Power Unlimited HV Lipo 5S 5100 mAh 35C, 19 volt at HV charge
  • In theory charging an HV pack at 4.2 volts will yield a 4500 mAh pack and is easier on the packs which if used correctly should result in a longer lasting pack.
  • F3A rules state the maximum voltage is 4.256
  • For practice and non-regulated events charging to 4.35 is probably undetectable.
  • Note: This may require a charger capable of HV charging above 4.2 volts per cell to get maximum mAh.
  • It is OK to charge to 4.2 volts and use normally.
Specifications:
  • Cells: 5
  • Volts: 18.5 volts charges to 21 volts
  • Weight: 515 grams 18.51 oz.
  • Length: 152mm / 6"
  • Height: 35mm / 1.38"
  • Width: 45mm / 1.85"
  • Output leads are 12 gauge cable (No connectors)
  • Balance Plug: JST/XH (Thunder Power, Gator RC, Hobby King)
Lighter packs are the result of: A more advanced ceramic diaphragm and electrode tab with high capacity density are now used during cells' production.
LINK - CLICK HERE
5S, 5800mAh, HV 35C Lipo Battery, Ultra Light (Power Unlimited)
Next generation Ultra Light (585 Grams) Power Unlimited HV Lipo 5S 5800 mAh 35C 19 Volt. Free shipping lower 48 when combined with other items to make $99 in total.
  • These lightweight packs have incredible power even when charged to a normal 4.2 volts per cell.
  • Amazing weight to performance ratio.Super Lightweight. 585 grams 19.9 Ounces
  • Next-generation Power Unlimited HV Lipo 5S 5800 mAh 35C 19 Volt at HV charge
  • 40 grams less than before the same great performance and capacity.Made to hold up to the rigors and high demands of F3A flying.
  • F3A Unlimited and Gator-RC worked diligently to bring this new line of Lipo's to market to meet these demands.
Specifications
  • Cells: 5
  • Weight: 565 grams/ 19.9oz
  • Length: 137mm / 5.4"
  • Height: 43mm / 1.7"
  • Width: 49mm / 1.93"
Lighter packs are the result of: A more advanced ceramic diaphragm and electrode tab with high capacity density are now used during cells' production. Note the following;
High Voltage cells can be charged to a maximum of 4.35 volts per cell. Normal voltage cells are charged to 4.2 volts per cell. The capacity of this pack is dependant on the charge.
Here are the test information from the factory
The battery is charged up to 4.35per cell, you will get 5800 mAh. The battery is charged up to 4.3V per cell, you will get 5500mAh. The battery is charged up to 4.25V per cell, you will get 5300mAh. The battery is charged to 4.2 per cell the mAh is 5000 mAh
4.299 Volts per cell is the legal limit for F3A when flying in competition.
LINK - CLICK HERE
May 17, 2020, 04:06 PM
I get this:
Service Temporarily Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Additionally, a 503 Service Temporarily Unavailable error was encountered while trying to use an ErrorDocument to handle the request.
May 17, 2020, 05:59 PM
Jim T. Graham's Avatar
Both links work from this side.
Discussion Choosing capacity for lipo receiver pack roberthabraken Batteries and Chargers 13 Mar 18, 2019 03:12 AM
Question Looking for a flat 3S 11.1V LiPo with medium-high capacity.. ZSimon Batteries and Chargers 1 Sep 12, 2011 06:16 AM
Discussion recommendation for VERY high capacity Lipo pack. bmaaa Large Electric Helis 4 Jul 04, 2009 10:25 AM
Battery pack life? High capacity high discharge Kevin Cox Electric Ducted Fan Jet Talk 0 Apr 26, 2002 09:21 PM
