This plane is one of the most versatile trainer planes on the market. You can take it from a beginner level to intermediate level by removing the NACA dropops.
The progressive design allows smooth advancement to the next level of RC flight
Removable plastic NACA droops for extra stabilization during training.
The Seagull P-47D MkII is not your average trainer, after your first takeoff, all doubt will be removed that this is the WARBIRD YOU WERE MEANT TO TRAIN WITH! With the NACA droops installed and low rates programmed into your transmitter this beast is a tame flyer. It easily flies big gentle patterns so you can work on your precise controls and top-notch takeoffs and landings. We recommend that you install the optional servos for flaps to add enhanced realism when you are ready to practice flap enhanced landings!
When youre ready to step up your training to the intermediate level; go to a 2 blade propeller and remove the NACA droops and kick up the control throws. Then the Seagull P-47D MK II becomes an intermediate/advanced Warbird. You will learn aerobatics while perfecting those spot-landing skills with the flaps. This model will get you ready for your next Warbird as you master a taildragger, flaps, and multiple advanced aerobatic maneuvers all from this incredible model!
TECHNICAL DETAILS
P-47D Little Bunny MK II 10cc with NACA Droops 55.2″ Wingspan SEA338
Wingspan .. 55.2 inches
Wing area ..560.2 square inches
Approximate flying weight 8.4 lbs
Length 45.2 inches
Recommended engine size . 8cc-10cc
ELECTRIC CONVERSION INCLUDED
Motor 60/1200 watt / 80A ESC / 6S LIPO with a 15Χ8 to 17Χ10 electric propeller
We have made it easier to buy these models at a 10% discount. You no longer need the NALL10 code. We directly discounted everything on our site! Thank you to those of you that have already placed orders. We truly appreciate it.
