May 16, 2020, 02:30 PM
robertus's Avatar
Build Log
MiG-21 EDF 70mm - Step by step with plans
Hello folks,
Allow me to announce my new project the MiG-21 powered by EDF 70mm on 4S.
It will be a little different than other. I'm going to share with you how I develop the project from drawings to the maiden flight. Step by step.
So let's start
MiG21 Scratch build - part1 (4 min 28 sec)
Unfortunately Windows recording doesn't shows context menu.
Edit: I forgot to mention. This is Sketchup.
Edit2: Plans are in #79
However, I recommend that you familiarise yourself with all pages earlier for better understanding the plans.
May 16, 2020, 03:26 PM
robertus's Avatar
Part 2
As you can see I always design only half of a plane
MiG-21 Scratch build part2 (4 min 49 sec)
May 16, 2020, 03:31 PM
robertus's Avatar
Part 3
Usually I upscale the wings and tail area by around 15% for more lift and stability.
Will see If it's not too much.
MiG-21 Scratch build part3 (2 min 43 sec)
May 16, 2020, 03:34 PM
robertus's Avatar
Part 4
1. Cleaning,
2. grouping
3. redrawing
Repeat until be ok.
MiG-21 Scratch build part4 (6 min 42 sec)
May 16, 2020, 06:22 PM
John Boren's Avatar
What software are you using to create this with?
John Boren
May 17, 2020, 02:10 AM
robertus's Avatar
John Boren
Hi John, this is Google Sketchup.
May 17, 2020, 02:18 AM
robertus's Avatar
Part 5
Still cleaning and redrawing some lines. At the moment I'm thinking how to divide model to the modules. Grouping helps in that.
MiG-21 Scratch build part5 (12 min 11 sec)
May 17, 2020, 02:39 AM
robertus's Avatar
Part 6
Detailing, nose cone.
Preparing modules. As you can see fuselage is divided to upper and lover module, for easiness of building.
MiG-21 Scratch build part6 (5 min 10 sec)
I'm not going to build a scale intake. I'll make cheat holes like in Freewing MiG-21, but from other hand I want to do some duct from nose cone for cooling the electronics.
May 17, 2020, 02:47 AM
robertus's Avatar
Part 7
Last corrections in the model and adding duct for EDF.
And at the end make a second half of MiG
Model in Sketchup is finished
MiG-21 Scratch build part7 (9 min 8 sec)
May 17, 2020, 02:50 AM
robertus's Avatar
Part 8
Now, It is time for unfolding surfaces. I'm using Unfold plugin for Sketchup for it.
First two modules: Wings/Tail and upper fuselage module.
MiG-21 Scratch build part8 (8 min 59 sec)
May 17, 2020, 03:19 AM
robertus's Avatar
I had to paste all parts quickly, because I'm in step 8 at the moment.
Now we are in the same time point in the build.
So, now I have plans for printing. Form Sketchup plans I can export to pdf. It is crucial to set camera to parallel and top view before export. Next I print pdf in adobe acrobat reader as a poster with cut markings. 100% scale of course. The 50mm square confirms that print is in scale.
May 18, 2020, 03:44 PM
fantastic job so far! love the MiG-21.
-beanie
May 20, 2020, 02:54 PM
robertus's Avatar
Small progress
May 20, 2020, 07:57 PM
really interested in seeing how you make yours EDF. i designed mine a long time ago using very similar techniques that you have used so far. but mine is a pusher, but i'd love to convert her to a 70mm EDF.
-beanie
May 21, 2020, 05:02 AM
Really nice, always wondered how jets are designed from the blueprints, thanks for documenting this, looking forward to your build, i would love to build this mig 21 someday, cheers
Build Log Mig-21 70mm foam scratch build FLYBOYRC40 Foamies (Scratchbuilt) 51 Nov 05, 2011 08:39 AM
Build Log 70mm Mig-21 Vernon Hunt Foamy EDFs 61 Mar 17, 2009 09:22 AM
Question HET 70mm MIG 21 FNFAL Electric Ducted Fan Jet Talk 14 Jan 12, 2009 01:38 PM
