E-flite Night Timber X
The E-flite Night Timber X 1.2m adds an integrated high-intensity LED lighting system to the 3D and STOL-capable Timber design so you can fly all day AND all night, too!
Night Timber X is Here
The E-flite Night Timber X 1.2m adds an integrated high-intensity LED lighting system to the 3D and STOL-capable Timber design so you can fly all day AND all night, too! It’s also Smart Technology ready with a Spektrum Avian 60-amp Smart ESC installed.
The E-flite® Timber® X 1.2m combined the STOL capabilities of the original Timber 1.5m model with a wing design featuring oversized ailerons and flaps, plus an enlarged rudder and elevator and a more powerful 3S and 4S compatible power system, to also deliver 3D performance you'd expect from an all-out aerobat. Now the Night Timber® X 1.2m adds factory-installed, high-visibility LED lights throughout the airframe for flying all day AND all night! It's also equipped with a 60-amp Spektrum™ Avian™ Smart ESC, and the BNF® Basic version is equipped with an AR637TA receiver that offers full-range telemetry including real-time battery voltage, current, temperature and more – along with motor reversing for special ground handling and other capabilities – when using compatible transmitters.
The E-flite® Timber® X 1.2m unleashed a new era of STOL plus 3D aerobatic capability. Based on the extremely popular Timber 1.5m model but featuring a new wing design, oversized control surfaces plus a 3S and 4S compatible power system, it offered an even wider flight envelope to deliver a truly "mild to wild" experience. And in addition to the standard LED landing, navigation and strobe lights, the Night Timber® X 1.2m adds integrated high-visibility LED lights throughout the airframe that make it possible to fly pretty much any time – day OR night! It also features exclusive Smart Technology via the 60-amp Spektrum™ Avian™ Smart ESC, and the BNF® Basic version is equipped with an AR637TA receiver that offers full-range telemetry including real-time battery voltage, current, temperature and more to compatible transmitters – plus reversing for special ground handling and other capabilities! Hollow-core EPO construction with composite reinforcement results in a lightweight yet strong airframe that offers the same flying weight as the original Timber X – even with the added LED lights. That also makes it capable of handling extreme aerobatic maneuvers while keeping the wing loading low for impressive Short Takeoff and Landing (STOL) and slow flight performance. It's also equipped with high-torque, metal-geared servos plus the shock-absorbing landing gear of the original model so you can fly as aggressively as you want from almost any surface. You can even install the included leading edge slats for improved slow flight performance, or the optional floats (sold separately) so you can fly from water all day AND all night too!
Features:
  • Incredible Short Takeoff and Landing (STOL) plus 3D capabilities
  • Integrated high-visibility LED lights to fly all day AND all night
  • Oversized control surfaces with double-beveled hinge lines
  • Six durable and factory-installed high-torque, metal-geared servos
  • 60-amp Spektrum™ Avian™ Smart ESC provides real-time battery voltage, temperature and other data, plus reversing capabilities, via compatible receivers and transmitters
  • Spektrum AR637TA receiver with full-range telemetry and industry-leading DSMX® technology
  • Easy to fly with innovative and optional-use SAFE® Select flight envelope protection
  • The unmatched stability and locked-in feel of exclusive AS3X® technology
  • Shock-absorbing landing gear with oversized tundra-style wheels
  • Functional and factory-installed LED landing, navigation and strobe lights
  • Lightweight yet durable composite-reinforced, hollow-core EPO construction
  • Includes optional-use leading edge slats for improved STOL and slow flight performance
  • Optional EDO-style floats (available separately) to fly from water
Check out the E-flite Night Timber X Here
Follow the Main Discussion Thread Here
May 16, 2020, 12:11 AM
eroeder's Avatar
Too bad the floats don’t have lights in them!
May 16, 2020, 07:08 AM
RCG Admin
Jason Cole's Avatar
Now that would be awesome!
Jun 02, 2020, 10:29 AM
+1, agreed, would buy definitely
Jun 02, 2020, 07:22 PM
I just want to go fly!
walter3rd's Avatar
i cant believe how much tech is in these planes these days. wow!
Jul 09, 2020, 11:00 AM
Maiden tonight
I picked up the night timber yesterday, built it, and programmed the radio. I'll maiden as soon as I'm off work today. I put the heavier metal tail spar to facilitate high alpha, but did not add the slats for STOL. I think it'll still have enough STOL capability to takeoff and land from my backyard. We'll see, it's a pretty small backyard. Plus I want to learn 3D flight and need a 3D capable plane. I actually went to the shop to pick up the new Ultimate 3D 950mm plane and it wasn't in yet, so this will do. I'll let y'all know how it goes.
Jul 19, 2020, 03:00 PM
I review RC Products
GBLynden's Avatar
This is my first Sunset Flight with the plane. As you can see, I have a lot to learn about 3D flight and I will likely add the heavier metal rod to the tail on future flights to see if that helps reduce the snaps to the side I was dealing with during this flight.
E-flite Night Timber X 1.2m BNF Basic RC Plane Sunset Flight (7 min 46 sec)
Article The NEW E-flite Night Timber X 1.2m BNFB/PNP...Smart STOL PLUS 3D — ALL DAY AND NIGHT Jason M Electric Plane Talk 1039 Today 12:57 PM
New Product E-Flite Timber 1.5m BNF Basic/PNP Mattfly Electric Plane Talk 17500 Jan 17, 2021 09:01 PM
Video E-Flite Timber night flight test robertmax Night Flying 0 Apr 01, 2017 02:02 AM
Video E-Flite Timber night flight test robertmax Parkflyers 0 Mar 31, 2017 03:37 PM
Discussion E-flite Timber Dave Eichstedt Parkflyers 18 Feb 27, 2017 04:24 PM
