Apr 18, 2005, 11:57 AM
Ian Easton's Avatar
Peter Rake Bristol Scout.
My Peter Rake designed Bristol Scout is one of my favourite models. I built this one a long time ago but shortly thereafter it was shot down by the dreaded interference at a field I no longer use. Finally I got it repaired to the point of making it flyable again. If you saw it up close you'de think it had been through the war but it does fly nice and look great in the air. Any others out there still making patrols of the trenches? I know quite a few were built.
Apr 18, 2005, 11:59 AM
Ian Easton's Avatar
Photos credits need to go to my daughter Amy.
Apr 18, 2005, 02:15 PM
farnboro flyer's Avatar
Ian, Photo 3 is just superb.........a big "big up" to Amy.
Of all the PR plans,( Apart from the SE2,) I like that little Bristol!Lovely.
Was it a free plan with FSM?
I rented from my local library 80 years of the RAF, and there is some nice footage of women pushing Bristol Scouts out of some hangers!
How about you posting up that Picture I sent you from my Dad's collection of the RFC
Bristol scout.
Ian
Apr 18, 2005, 03:10 PM
Ian Easton's Avatar
Here it is...
Apr 18, 2005, 09:06 PM
Trampling out the vintage
Nice photos. I must build another one of these. I flew mine so much I sort of "loved it to death".
I have done a lot of research on the Bristol Scout and that is the first photo I've seen showing the instrument panel, very nice.
Apr 19, 2005, 02:50 AM
Greg, That photo I sent to Ian is a very clear RFC picture with some interesting comments on the reverse........
Quote, "The planes are Bristol &have been on the machine since purchase....(R/h top plane excepted)White paint was put on the planes over the old surface at XAD 14.6.17"
Planes total in air 39 hrs.
Planes since white paint 34hrs 45mins.
The white paint has been slightly damaged by a fire extinguisher
With a stamp says X Aircraft Depot Laboratory. Date 24.8.17 Royal Flying Corp.
No of machine is quoted as ?5603
Ian
Apr 19, 2005, 06:21 AM
Greg, Unable to send you a private message.
Am asking if you would like the full file of that picture, with reverse side notes?
Ian
Apr 19, 2005, 06:41 AM
Thanks Ian PM sent.
Apr 19, 2005, 08:23 AM
Ian Easton's Avatar
Here it is - I meant to post it too...
Apr 19, 2005, 10:58 AM
Nice Photos! I am just finishing up an AerodromeRC Bristol Scout witch as I understand is sort of a colaboration between Peter and Kurt. I have to admit, it has turned out even better than I expected! This is a great build and a beautiful little plane. I hope it flys as well as it looks. I will post some pics when I get the tail feathers mounted later this week!
Apr 19, 2005, 12:18 PM
Well Ian, you have kinda re-kindled my interest in that little beauty!
I think it deserves a flight or three over South Farnborough.
Ian
Jul 21, 2005, 03:33 PM
Baumer, Did you get the Bristol Scout in the air?
Ian
Aug 17, 2005, 01:13 PM
Ian
Sorry I'm so slow responding - been on a little vacation! Yes, I did get her in the air and she flys beautifly!! A bit underpowered at first as I put in a small Himaxx brushless and tried to power it with a 2c 1500mah lipo. Swapped in a 3c lipo and it was perfect! She looks great in the air and handles nicely with no bad habits just as Kurt said. Very cool! I have struggled with landings a little as she doesn't seem to like flying slowly and tends to stall close to the ground. I am going to try bringing her in a little hotter and cut power at the last minute. I don't have much experience with these WWI planes yet - any ideas?
Baumer
Aug 17, 2005, 02:09 PM
portablevcb's Avatar
Baumer,
Fly it down. While flying level (at altitude) lower the throttle until you can see the tail droop a bit. Use that as a reference for your approach. Keep that attitude with the elevator and use the throttle to control how fast the plane comes down. Don't really flare. Pulling on the elevator will just encourage a balloon/stall. In fact a short/small burst of power near touchdown will slow descent a bit and the wheels will just kiss the runway (not too much of a burst!). Hold the elevator at that position so the tail doesn't come up and nose over (even though it still might if you hit a bit of grass or a rock!).
Now, this is much easier said than done!!! I am just now getting the hang of it after hundreds of landings. The SPAD is what has taught me how to get the feel of it. Tritle has tried to teach this to me and I have always fallen back on the elevator as the main landing control. Not good This is even after learning the proper way in full size! Gotta hit me on the head with a 2x4 before I learn anything
Nice planes!
charlie
Aug 19, 2005, 03:09 PM
Now that sounds easy! That smiley expresses exactly how I feel every time I bring this bird in on approach!
Thanks for the tips! I really appreciate it. Everything you suggest makes a lot of sense to me after several attempts now. I have relegated myself to the fact that this is just going to the plane I learn how to fly a WWI scale model with. I just hope I don't dash it to toothpics before I get the hang of it!! So far I have broken a few wing struts, cabane struts and torn one of the bottom wings clean off! Happily, nothing has been even close to beyond repair.
Let me take this moment to RAVE about the strength and durability of Polyspan as a covering material. It is unbelievable to me that I can hit the ground hard enough to tear a lower wing off and splinter struts and yet have no damage to leading edges or ribs!! Not only does it lend tremendous strength, it looks terrific and very realistic. The knock I always hear is that it doesnt conform around compound curves very well. I found this to be untrue. It may take a little more care, however, I discovered that if I worked thie edges slowly with a hot iron that the fabric would almost melt around the corners. Sometimes there would be a little sagging or gathering of the material, but again if I worked the location on the corner where the fabric adheres to the wood slowly, pulling with just the pressure of the iron on the wood in the proper direction to tighten the sagging that within a few minutes it would tighten right up and leave me with a perfect wingtip! Fantastic stuff!!
Discussion Peter Rake Bristol Scout prototype portablevcb Scale Kit/Scratch Built 30 Jun 05, 2012 12:32 AM
Build Log Peter Rake AVRO Scout racer Pat Lynch Scale Kit/Scratch Built 158 Jun 04, 2011 05:04 PM
Peter Rake's Bristol Scout finally ready LawrenceHare Scale Kit/Scratch Built 11 Apr 05, 2004 05:10 PM
24" Bristol Scout - Peter Rake Design Goodychrischild Scale Kit/Scratch Built 98 Apr 23, 2003 11:49 AM
To Peter Rake re: In-Out, Scout About Warren Jones Scale Kit/Scratch Built 11 Feb 26, 2003 10:13 AM
