This thread is privately moderated by Piece, who may elect to delete unwanted replies.
May 11, 2020, 08:52 AM
Wake up, feel pulse, be happy!
Piece's Avatar
BLHeli ESC + Tamiya buggy + 6S lipo
I originally bought my DT-03 for FPV, with no plans to do any crazy modifications.
Except I couldn't just ignore the combination of BLHeli's extraordinary low-RPM sync and torque, and the "bidirectional" setting that lets any random quad ESC run forward/neutral/reverse. Plus, quad ESCs are incredibly good at what they do. Active freewheeling bypasses the old part-throttle heating issues, resulting in a very tiny, lightweight ESC, and the "brake" is always active, slowing the motor down by force as soon as the throttle is reduced.
So long story short, I installed a cheap 3100Kv 3650 size motor, with the test ESC being some 30A BLHeli-S unit rated for 2S-6S that weighs about 4 grams. Initial tests rolling around my apartment showed it gives just a small jerk to get moving, but once the rotor is turning, the ESC will slow it down to a bare crawl and keep it there without effort. It makes the stock brushed setup seem like an uncontrollable rocket by comparison... and the torque is there, baby. I started shoving various objects and finally got the knobby tires to slip pushing a gallon jug of water, although the buggy was still able to move it around.
The braking is scary. It doesn't coast - you increase throttle, the motor speeds up. You decrease throttle, the motor slows down, by force. Backing off the throttle too quick can send the car skidding even more easily than punching it too hard (because the front has no brakes, duh), which is tricky to control (at least on rough, sandy asphalt with worn-out tires).
I ran it outdoors on a 2S li-ion, and then a 3S lipo, and the ESC barely got above ambient temperature. Power is pretty nutty on 3S - the top half of the range was basically unusable. I decided to try the 6S lipo anyway, which proved to work just as well as 2S at low speeds (smooth, controllable, no noticeable temp increase), but it caught fire when I started trying to do speed runs. It was only a 30A ESC, remember, so the fact that I was able to drive it around and make several fast passes on 6S in the first place is pretty neat.
Anyway. Looks like the fire started at the caps, not the FETs, so I'm guessing motor inductance is a problem here. I've already ordered a beefier ESC (80A, 8S, BLHeli32) and some big caps to go with it. Should be interesting.
And oh yeah, I haven't forgotten about FPV
May 17, 2020, 09:19 PM
Piece's Avatar
Box arrived. Got everything soldered up, then spent all night wrestling with firmware and downloading stuff before I was able to program the ESC... but it does work. In fact, it works a lot better than even the BLHeli-S version. The 32-bit controller starts more smoothly and consistently, and the "non-damped" setting solves the harsh braking that made it so hard to control on the last attempt.
I'll need to get outside to test it at higher speeds (and gather realistic current data) but here it is showing off its low-RPM performance.
First test runs with the BLHeli32 buggy! (3 min 4 sec)
May 17, 2020, 10:23 PM
If it flies, I can crash it.
rocketsled666's Avatar
Hmm. I have a Tamiya Wild Willy, which came brushed, but was built brushless. I was thinking of swapping in one of my old sensored brushless motors because the low speed performance was poor. Impossible to get the car moving without popping a wheelie. But I have plenty of Quad ESCs with BL_Heli and you're right about low speed performance with props. Worth a shot with a gearbox! I'm gonna give this a try.
Dec 08, 2020, 05:15 AM
Piece's Avatar
This project has been so smooth and unremarkable that there hasn't been much to add. I bought a cheap ($20) pistol style radio which works great and massively improves the experience, and I ended up making a real 4S pack of 18650 cells to go in place of the 2S2P that I started with. 4S seems ideal. Going to 6S is like adding 500HP to a 1000HP street car... like, it really just means you need less throttle to destroy the same amount of tires.
The iFlight 80A ESC loves its job. It doesn't have problems. It doesn't warm up. I haven't even adjusted any settings since the night I installed it. Overall, considering my absolute lack of knowing what I'm doing with RC cars, I'm pretty happy with the one I've ended up with.
Managed a whopping 38mph in a huge parking lot before I realized this is the wrong chassis for speed runs. Sticky road tires really only made it easier to flip over on pavement. It's a lot more fun with the spike tires in grass, especially since they don't get completely shredded in like half a battery.
FPV is fun, but LOS bashing is growing on me. The next step is to waterproof the electronics so I'm not stuck waiting for dry weather (six months from now).
Beyond all that, it looks cool sitting on my shelf, which was like 33% of the initial goal
Jul 10, 2021, 05:17 PM
That's really cool!
New Product 6.5g XJB V1 F3 EVO FC AIO 5V BEC PDB with XR25A 25A Blheli 2-6S 4in1 ESC sevet Multirotor Drone Electronics 6 Jun 16, 2017 04:25 PM
Discussion SunnySky 380kv motors, BLHELI, 1555 and 6S? Timing/ESC settings? wifiguru10 Multirotor Drone Power Systems 3 Sep 23, 2016 11:04 AM
Discussion sk450 with 4 Turnigy Multistar 20A V2 ESC With BLHeli and 4A LBEC 2-6S neo37ww Beginner Multirotor Drones 0 Jul 29, 2015 06:09 PM
Discussion 4 in 1 30A/20A Brushless ESC Blheli Firmware 2-6S w/USB Programmer for RC Models strips Multirotor Drone Electronics 5 Jul 28, 2014 01:56 PM
Discussion ESC to use on Vintage Tamiya RC buggies Finalunity Off-road Cars 3 Jun 11, 2012 05:25 PM
