May 02, 2020, 06:42 AM
LK 2018 D 1-1/8" Reverse RC Boat Turbo Jet
Anyone have input on this jet drive unit. Was thinking of putting it in a Dumas SK-Daddle which is a
36" length hull. Would like to make it look like some of the jet ski boats from the 80's with a V-8 motor
to cover the motor & pump.
May 02, 2020, 07:13 PM
Just Plane Nutts
AirDOGGe's Avatar
1-1/8" = 28mm-29mm
Don't know much about them, but the design looks OK from the outside. I'd need to know more to make a judgement though.
SK-Daddle may do OK if the transom is tall enough for it.
Latest blog entry: My You-Tube channel
May 07, 2020, 07:07 AM
Well I took the chance and ordered the jet drive to see what it looks like and will get the SK-Daddle kit off the shop shelf and see if this is going to be a suitable hull for the jet pump, as I remember from the last one I built the transom is nearly flat on the bottom, so hopefully modifications to the hull will be nominal.
May 09, 2020, 04:13 PM
Came across the MSQ Water Jets from Ali Express, anyone have any info on them?
https://www.aliexpress.com/item/4000...dcae57ab7GX3fb
May 26, 2020, 07:23 AM
Ordered the MSQ 36mm water jet from Ali Express for the Dumas SK-Daddle 40 , will be powering it with a SSS 3674 1650kv motoron 4 cells, also ordered the 36 mm 4-bladed impeller for it. Should arrive in about the next couple of weeks, need to et busy on the boat build and modification for the jet pump.
https://www.aliexpress.com/item/4000...2f7f4c4dDxHM4E
Will be doing the build in another thread........
Discussion Caddx Turbo Micro SDR2 1/2.8 2.1mm 1200TVL Low Latency WDR 16:9/4:3 FPV Camera for RC scousethief Banggood.com 2 Aug 06, 2018 04:23 PM
Discussion RC bike 1/5 World 2018 in France +1/8+Warm Up lalain Motorcycles 2 May 01, 2018 11:19 AM
mp jet 26/45/20-d 2.8/1 geared pikebishop Electric Power Systems 0 Dec 26, 2003 02:25 PM
