This thread is privately moderated by Mad_angler1, who may elect to delete unwanted replies.
May 01, 2020, 08:16 PM
Bog Flusher Platinum Grade
Mad_angler1's Avatar
New Product
The Cube Autopilot
The Cube Autopilot
What’s the next big thing after Pixhawk? Why wait to find out! You already know
The Cube Autopilot offers a powerful autopilot ecosystem for use in a wide range of applications with Ardupilot and PX4.
The Cube’s foundations are based on a Cube module with a growing ecosystem of carrier boards and accessories that allow users to design a system that best suits their application and needs.
For future upgradability every Cube module is fitted with the same connector ensuring full backwards and future compatibility.
On this, Philip Rowse CTO of Cubepilot says
Your companies future is secured with a cube at its heart, from the day that ProfiCNC came up with the concept of the Cube in 2013, to today, we have promised our users that they are future proof. We will maintain this promise, ensuring that your legacy platforms remain current with 100% plug in upgrades to the latest technology!
Hardware Redundancy
The Cube’s design helped set the standard for sensor redundancy in an autopilot, all models apart from the Purple feature triple IMU sensors of which two are located on an internally vibration isolated temperature controlled module.
Open Source Flight Software
The Cube is proudly running the world’s most trusted autopilot code, Ardupilot! Don’t trust your future to anything less.
The Cube Autopilot comes with no software installed allowing you to choose the software that best suits your needs. The Cube series is compatible with both Ardupilot and PX4 and is fully supported in both Mission Planner and QGroundcontrol.
Cube Autopilot Models
Originally starting with the Cube Black the range has since expanded to include powerful STM32 F7 and H7 models as well as the US manufactured Blue Cube and a wide range of carrier boards including the new ADS-B In version in corporation with uAVionics.
The Cube Orange
The Most powerful Cube Autopilot
The Cube Orange is the latest Cube and the most powerful version of this autopilot. Using the STM32H7 series its over twice as fast as the the Cube Black. The H7 is based Cortex-M7 on a new 40 nm architecture with double precision floating point units, an onboard crypto unit and 2Mb of RAM.
Having the new powerful SOC the Cube Orange allows users developers to harness even more from their autopilot.
Users can take advantage of this extra power with the ability to run multiple Lua scripts directly on the SOC allowing for a massive amount of new customisation for your application .
Spec
STM32H743 400 Mhz SOC
Triple Redundant IMU
Dual IMU Heated & Internally Isolated
2Mb Ram / 2MB Rom
Sensors
CM20602
ICM 20948
MS5611 Barometer
Application
The new standard for general UAV and ground/water based applications with Ardupilot and PX4.
Cube Black
The Original Autopilot On A Module
The Cube Black was the first in the Cube series and features
STM32 F4 180Mhz SOC
Triple Internal Redundant IMU
Dual IMU Heated & Internally Isolated IMU
256K Ram / 2MB Rom
Sensors
LSM303D integrated accelerometer / magnetometer.
L3GD20 gyro.
MPU9250 Gyro / Accel
MS5611 Barometer
Application
Ideal for general UAV and ground/water based applications with Ardupilot and PX4 but has now been replaced with the Cube Orange for most users.
Cube Yellow
STM32 F7 Based for Custom Applications
The Cube Yellow was released along side the Orange and is fitted with the STM32F7 series SOC. Featuring a Cortex-M7 on the 90 nm architecture It still had double precision floating point units but runs at a slower clock speed compared to the H7 model.
The Cube yellow offers many performance improvements over F4 based Cube black and allows users developers to harness even more from their autopilot. The Yellow Cube is ideal for PX4 users or custom applications where STM F series architecture is required but need more power than the Cube Black.
Spec
STM32F777 216 Mhz SOC
512K Ram / 2MB Rom
Sensors
CM20602
ICM 20948
MS5611 Barometer
Application
UAV and ground/water based applications with Ardupilot and PX4 and custom applications where STM F series is required.
Cube Purple
Autopilot On A Module For Rover or Boat
The Cube Purple is a small form factor version of the original Cube Black, specifically for ground or water based applications where redundant and internally isolated sensors are not required.
Spec
STM32 F4 180Mhz SOC
Single IMU
256K Ram / 2MB Rom
Instal Barometer
Internal Compass
Application
Ground/water based applications with Ardupilot and PX4.
Cube Blue
The Original Autopilot On A Module Manufactured in USA
The Cube Blue is made in the USA for applications where this is a requirement. Its main overall spec is the same as the Cube Black.
Spec
STM32 F4 180Mhz SOC
256K Ram / 2MB Rom
Sensors
L3GD20 gyro.
MS5611 Barometer
Application
Custom and Industrial Applications where US Manufacturing is required.
Carrier Boards
One of the major benefits of the Cubepilot ecosystem is that the Cube module and connection IO carrier board are separate, this allows you to choose a setup with the connections and features for your specific needs. For developers and system integrators the Cube Autopilot is the perfect solution for you, today there are over 70 publicly registered carrier designs and If none of these suit your needs Cubepilot (ProfiCNC & Hex Aero) publish the carrier board PCB files under licence for use as a template for system integrators develop their own.
Cubepilot say
Below is a small selection of the carrier boards available
Standard Carrier board that now has integrated UAVonics Ping ADS-B In module.
The carrier board mini for applications where space is a premium.
The Kore Board for simple multi-rotor configuration
Peripherals
Along side the Cube they also make a number of peripherals and accessories.
Here 2 GPS
Built-in STM32F302 processor chip running a real-time operating system ChibiOS
CAN & Serial Connection options on same module
Onboard IMU including an accelerometer, compass and gyro
4 independent and customisable LEDs can be set to indicate different flight status
Built-in MS5611 barometer on CAN bus for those who need external barometer due to internal placement of flight controller inside an airtight aircraft.
More information can be found on the Cubepilot website
I have created a video showing the deferent models and what options are best for you. No matter of your a Ardupilot user with Arduplane or Ardicopter or your a PX4 user they have a Cube that will suit your needs.
Also if your looking to add ADS-B capability the new carrier board includes and Avionics ADS-B receiver onboard for use with Mission planner.
CubePilot Models Overview
The Cube Flight Controller Models Compared + Uavionix ADS-B Carrier Board Discussed (15 min 28 sec)
The Cube Orange with ADS- B In
The Cube Orange Autopilot/Flight Controller With ADS-B Overview, Setup & ADSB Demo (12 min 17 sec)
May 01, 2020, 08:17 PM
I have created a thread for this https://www.rcgroups.com/forums/show...Cube-Autopilot
For more information, help and support please post In this thread and I will try to answer questions for people if I can.
Discussion Polaroid Cube+ / Polaroid Cube Plus Pixelpeter Aerial Photography 3 Mar 05, 2016 08:23 AM
News Lynx Heli Innovations OXY 3 Cube System ndfly700 Mini Helis 4 Nov 13, 2015 12:12 AM
