I have a couple to build and I'd like a change to Hot Glue. Pat |
https://hobbyking.com/en_us/clear-fo...rge-100ml.html |
Pat |
Hello guys, I decided to glue the three layers of the wing with the Uhu Por. The engine mount with epoxy. The rest of the parts with this glue
https://www.amazon.co.uk/Adesivo-Bos.../dp/B00ABJS3IQ |
Fun Plane!!! A favorite 👌
Mine is 300 grams with a EMAX ECO 2306 1700kV, 3S800 graphene, ESC 20A, 7x5 APC and hot glue (wings with very thin UHU Por). Building time: 3 evenings NO watching TV..... Static thrust 630 grams (vertical starts are fun) at 230 W and 21A. Flying time is 10 minutes cruising, rolls and upside down (very neutral and easy) or 7 minutes racing. Full power at very tight turns, the wings bend but do not snap 😁. Incredible slow AND fast flyer, acceleration is impressive (due to low weight and high power). Thanks for sharing this design. 👏 |
Reason: pictures added
Hi guys, mine is ready for testing. Auw weight 320 gr, including br2208-1400 motor, prop gws 8x4.3 sf, 20A esc, 3x9gr servos, 1000 mah 3s battery. Easy construction. This is my first model with the kf4m profile. Thank you.
Hi guys, first test flight done !! With the engine written in my previous post, you can easily fly at 50/60% of power. Be careful, use dual rate and expo because it is very responsive.
I used a gws 8x4 EP and not slowfly. With an battery 850 mah 3S the flight time was 5 minutes, but you can easily do 6 minutes. AUW was 320gr. I am very satisfied. Next step add some decoration. |
Thread Tools | |
Similar Threads | |||||
Build Log | Balsa vs. Depron: Jupiter Scout free download plan | Thomas B. | Parkflyers | 162 | Apr 14, 2024 06:34 AM |
Build Log | Sikorsky/Jupiter S 39 Free Download Plan | Thomas B. | Waterplanes | 4 | Jul 15, 2020 12:27 PM |
Build Log | GMP Laird Super Solution (Golden Era Racer) ARF Build | AeroKraz | Giant Scale Airplanes | 15 | Nov 18, 2016 03:48 PM |
