This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Apr 18, 2020, 09:34 PM
old4570's Avatar
Calamity Jane ( Micro F16 )
Calamity Jane Micro F16 (3 min 44 sec)
I did some work on correcting the motor thrust angles as well I put 3 pieces of lead shot in the nose .
It flies !
CG is still to far back and the F16 hunts both up and down in flight ( CG is too far back ) .
Also I cooked the 8520 . Even though I was at like 50% throttle , the motor cooked .
The prop hub melted the motor got so hot .
Came home , re glued the motor and found a new prop .
I will put a little more lead in the nose , see if I can't correct the F16 hunting so much .
Also I will need to do some cooling for the motor , or it will simply cook again .
I may even have to order another 8520 ( I have one on order At The Moment - ATM )
I have plans for that 8520 ordered .
Hmmm , Should I do a brush less Flybear FX723 ? Something to think about once this one is sorted .
Apr 19, 2020, 12:08 AM
If it flies, I can crash it.
rocketsled666's Avatar
That's a real smooth flyer.
Apr 19, 2020, 01:40 AM
old4570's Avatar
Hopefully ! Once the CG is corrected and the motor does not cook .
I did quite a bit work on the cooling . Should be a lot more air passing over the motor now .
Discussion Burlington College Closes Due To “Crushing Weight of Debt” Acquired By Jane Sanders kenpoprofessor Life, The Universe, and Politics 5 May 17, 2016 03:16 AM
Discussion PDB with all the bells or plain jane? jeff262 Multirotor Drone Talk 2 Jan 30, 2016 10:34 PM
Discussion Great Planes Fling Calamity Bruno Stachel Hand Launch 7 Oct 06, 2011 03:32 PM
What are the odds? 2 Simultaneous Calamities blakbird Parkflyers 13 May 05, 2003 04:40 PM
