Apr 11, 2005, 10:13 AM
3d_Crazy's Avatar
24" R3D-minis for CDROM Power Part 3
This is the new thread for the 24" R3D-mini's designed for CDROM power.
More information can be found at: www.e-foamies.com
Here is a link to the last thread (#2): https://www.rcgroups.com/forums/showthread.php?t=297123
And here is a link to the first thread (#1): https://www.rcgroups.com/forums/showthread.php?t=258159
Tim
Electric Foam Models
e-foamies.com
Apr 11, 2005, 10:55 AM
davidsons's Avatar
subscribed
Apr 11, 2005, 12:37 PM
Happy Days
mudlark's Avatar
This tread will never end. Great plane Tim
Here is an evening pic of my one. I've modded the tail with the addition of balancers. Also added 1 inch to the tips of the elevator for better control. Great flier. Have now upgraded the motor to a Hacker A20 S34 on 3sLipos TP480ma on an 8x4 gws HD prop, to say it is over powered doesn't come close.
Dave
Apr 11, 2005, 12:42 PM
Very cool paint scheme.
Apr 11, 2005, 12:59 PM
Happy Days
mudlark's Avatar
Cheers Bill.
Just used dayglow spay can paint from a DIY store. Shows up realy well, even into dusk. Have ordered some glow in the dark paint, should be fun.
Dave
Apr 11, 2005, 04:12 PM
Father, Skydiver, Photographer
Bill K.'s Avatar
Ah... much better... Thanks Tim!!
May 08, 2005, 08:27 PM
FlyTime's Avatar
Mini 3D
Here is a pic of the paint job on my second Mini 3d. I only paint the underside and leave the top side stock.
May 08, 2005, 08:51 PM
3d_Crazy's Avatar
Sweet! That should be easy to see. Looks great!
Tim
May 08, 2005, 08:58 PM
FlyTime's Avatar
Great plane Tim
Thanks. I also posted my almost completed Rev 3d V2 trainer along with this assembly tip.
After building two Mini 3ds and a Revolution 3d trainer, all ARF versions I found it much easier to completely assemble the horizontal stabilzer and elevator ( cut hor stab from elev, cut bevels and tape hinge) first then cut the slit in the back end of the fuse keel and key hole for the elev clearance and slide the completed Hor-stab-elev assembly into postion and glue.
see https://www.rcgroups.com/forums/show...13#post3722516 for post
I only wished I took some pics to show ya....
j
May 08, 2005, 10:25 PM
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
As part of a "how cheap can you 3D" experiment, we're flying one on the towerpro/BP/whatever 21 turn outrunner. The extra weight means we had to cut the motor mount block pretty short and the motor is wedged back up inside the plane pretty far.
It's more than enough power, and dang, that ugly little motor is tough! The difference in mass between the cd-rom and the heavier motor is quite noticeable, though. It hurts the handling more than a little.
Anyway, great little plane. We have plenty in stock at www.3DHobbyShop.com
May 16, 2005, 07:16 PM
The new Hyperion motors are just about perfect for the mini. I've been flying this one w/ the 2205-38 and 8-4 prop on etec 3S 450...AUW 6.4oz. The 8-6 prop is good on 2S with the same motor. Great plane, Tim.
May 16, 2005, 08:09 PM
davidsons's Avatar
Great hover shot blucor...did you take that yourself while hovering?
May 16, 2005, 09:34 PM
Of Course.
May 17, 2005, 07:15 PM
I bought me a mini a while ago and I will be darned it I can get it to fly. I am sure it is my problem because I am not a 3D flyer by any means. Anyhow, I have the plane and want to fly it!!! Where would be a good COG to tame this thing down. I have the rates turned way down right now. Any other tips appreciated too. Thanks!!!!
May 17, 2005, 07:25 PM
3d_Crazy's Avatar
What are your Exponential rates set at? Do you have dual rates programed? If so, what are throws on High and Low rates? And the last question, where is your CG currently?
Tim
Discussion Mini 3D EPP for CD brushless: Part 3 sloper steve Foamies (Kits) 6150 May 26, 2008 07:12 PM
Lvc Cut Off For Thunder Power 2 And 3 Cell Batteries MRD Batteries and Chargers 4 Aug 10, 2005 05:01 PM
24" R3D-mini's for CDROM power! V2 Martin Hunter 3D Flying 507 Apr 11, 2005 04:05 PM
24" R3D-mini's for CDROM power! 3d_Crazy 3D Flying 680 Nov 10, 2004 10:17 AM
E-Foamies Challenger II Mini for CDROM Power! 3d_Crazy 3D Flying 234 Oct 27, 2004 01:54 PM
