DJI FPV System Firmware Update
DJI just dropped the latest firmware for their HD FPV system and it has some nice feature updates that people have been waiting for.
New Firmware for DJI FPV
DJI just dropped the latest firmware for their HD FPV system and it has some nice feature updates that people have been waiting for. You can finally get HDMI out to a monitor from a Smart Controller, see the home point on screen and more. Check out the full list of update notes below, but also of interesting note is the updates adds support for a Caddx Nebula camera model. What is the Nebula? Your guess is as good as mine, but we'll likely have info on this new DJI compatible camera from Caddx shortly.
Full Firmware Release Notes:
  • Date: 2020.04.13
  • Air Unit Firmware: v01.00.05.00
  • Goggles Firmware: v01.00.05.00
  • Remote Controller Firmware: v01.00.05.00
  • DJI Assistant 2 (DJI FPV Series): v2.0.2
What’s New?
  • Added ability to view HDMI live broadcast by connecting the goggles to the DJI Smart Controller (v01.00.07.00 or above). By connecting the goggles to the DJI Smart Controller using USB-C cable, users can see the camera view of the air unit on the screen of the Smart Controller, and then can transmit the live view from the Smart Controller to other display devices through an HDMI cable.
  • Added new custom on-screen display information: home point direction, home point distance, altitude, and GPS speed.
  • Added on-screen flashing prompt on the goggles when the signal of the air unit or the remote controller is weak.
  • Added menu setting to choose to enable recording after unlocking the flight controller.
  • Added menu setting to choose to enable the low battery warning alarm of the goggles.
  • Added support for Caddx Nebula camera model.
  • Optimized display and operation in the AV IN interface. Added menu setting to adjust screen size and position and added on-screen display for the battery level of the goggles.
  • Fixed issue: screen blurred or froze when unlocking Air Unit (Lite).
  • Fixed issue: operation was delayed when using the remote controller on a simulator.
  • Fixed rare issue: the PID tuning did not take effect after changing the settings.
Notice:
  • Restart the air unit, goggles, and remote controller once the update is complete.
  • Make sure that the firmware of the air unit, the goggles and the remote controller are in the same version. Check the firmware version in Setting, Device Info, and then Device Info on goggles.
  • If the firmware update fails, restart the device and DJI Assistant 2 (DJI FPV Series), and try updating again.
  • Update the Air Unit (Lite) when there is good ventilation. Make sure that both the goggles and remote controller are powered off before updating the Air Unit (Lite). DO NOT touch the Air Unit (Lite) during update since the temperature rises. If update fails, wait for the Air Unit (Lite) to cool down and try to update again.
May 13, 2020, 09:12 PM
Bhodi11's Avatar
Is it possible to move the stock DJI OSD info around at all? I am having trouble being able to focus in on the lower outside corners where they are by default. No matter how I adjust the lenses in or out I just can’t get them clear. The betaflight OSD info I have moved in more and can read just fine.
Discussion DJI Phantom 3 Standard Firmware Update UAFDRONE Multirotor Drone Talk 0 Apr 23, 2016 08:57 PM
Download A New Firmware Update Is Now Available For DJI Focus DJI INNOVATIONS Multirotor Drone Talk 0 Dec 03, 2015 06:04 AM
