This thread is privately moderated by lightning10811, who may elect to delete unwanted replies.
Apr 10, 2020, 02:33 AM
Help!
Inav inavflight launch mode problem
have matek 405wing, inav 2.3 in a skyhunter.
Problem: launch mode will only activate and work when manual mode selected. I select launch, then mode other than manual (RTH for instance) then arm, then set throttle. The board will not proceed to auto launch. But if I leave it in manual mode, set launch, arm board, set throttle then it works. I have tried setting RTH (or horizon mode), then go through the above process and this doesn’t work either. Seems as if auto launch only works when manual is selected.
Any thoughts?
Discussion The correct launch mode set up? i_am_mark_evans Hand Launch 11 Mar 05, 2016 02:56 PM
Discussion Pixhawk: problem with transition from manual mode to position control mode florian9876 Multirotor Drone Talk 0 Nov 22, 2015 01:53 PM
Help! How To Program A Launch Mode -Futaba 7C TX joe1 Radios 0 Nov 20, 2015 03:52 PM
Discussion Programing launch mode and getting a better launch Evan D Thermal 14 Aug 15, 2011 06:27 PM
Glider Mode speed/launch modes. RyanPSU21 Hitec/Multiplex USA 8 Jan 03, 2004 06:09 PM
