Apr 09, 2020, 11:11 PM
FrSky-MKT
New Product
FrSky New Arrival R9 SX & MX Enhanced R9 Series ACCESS OTA Long-Range Receivers
R9 MX
Overview
The R9 MX is the enhanced versions of the previous R9 MM/Mini series long-range capable receivers, equivalent in size and weight equipped with a robust detachable Ipex1 antenna connector.
Name: R9 MX -1.jpg
Description: Name: R9 MX -2.jpg
Description:
The R9 MX takes features from the previous R9 Mini and R9 MM making it compatible with more external devices by providing an Inverted S.Port output and supporting the redundancy function. Additionally, it retains soldering points to connect 4 PWM channels. The enhanced design proves to be more durable, and in conjunction with the latest ACCESS firmware, the two are now synchronized and we are able to unlock the true potential of the ACCESS protocol.
Specifications
  • Frequency: 868MHz / 915MHz
  • Dimension: 18*12*3.2mm
  • Weight: 3.2g
  • Numbers of Channel: 4 PWM / 16 SBUS (CH16 outputs RSSI)
  • Operating Voltage: DC 3.5V~10V
  • Operating Current: [email protected]
  • Compatibility: R9M Lite/ R9M Lite Pro / R9M 2019 with ACCESS firmware
Features
  • ACCESS protocol and supports OTA functions
  • 900MHz/868MHz long-range with low latency
  • Enhanced and durable design
  • Support S.Port / F.Port (Configurable in OpenTX / FrOS menu)
  • With inverted S.Port outputs
  • Signal redundancy function
  • Detachable Ipex1 connector antenna
MORE DETAILS: https://www.frsky-rc.com/product/r9-mx/
R9 SX
Overview
The R9 SX is the enhanced version of the R9 Slim series of long-range capable receivers. It adds 3-pin servo connectors with 6 full PWM channels and utilizes the dual-antenna design. The light-weight protective shell has a Multi-use 6-pin plug to bring you additional functions like signal redundancy, telemetry feedback, external battery detection and more.
Description: Name: SX 1-1.jpg
Description:
Flexibility is a key feature of this receiver. The 6 PWM channels can be converted to 4 PWM channels with the additional Ch5 and Ch6 can be configured as an alternative S.Port and SBUS outputs to the 6-pin port. The enhanced design proves to be more durable, and in conjunction with the latest ACCESS firmware, the two are now synchronized and we are able to unlock the true potential of the ACCESS protocol.
Specifications
  • Dimension: 36*17*7mm / 47.5*20.5*11mm (including case and pins)
  • Weight: 8.8g / 13g (including case and pins)
  • Numbers of Channel: 6 PWM / 16 SBUS (CH16 outputs RSSI)
  • Operating Voltage: DC 3.5V~12.6V
Features
  • 6 standard servo connectors (default PWM channel)
  • Switchable CH5/CH6 into S.Port/SBUS Output channels
  • External battery detection
MORE DETAILS: https://www.frsky-rc.com/product/r9-sx/
Apr 12, 2020, 07:10 AM
Suteki's Avatar
After an R9MM went into failsafe and killed the fuselage of one of my planes coupled with the fact no other antenna was compatible because of the iPex 4 connector, I'm happy to see this being released.
At least I'll be able to get pare antennas locally now as everyone else is making iPex 1 connected antennas.
Apr 24, 2020, 07:27 PM
Any word on availability?
Apr 26, 2020, 01:12 PM
Price?
Cheaper than TBS Crossfire Nano RX at now $24.95?
Apr 26, 2020, 06:04 PM
Suteki's Avatar
Originally Posted by gorro View Post
Price?
https://www.horusrc.com/en/receivers/r9-series
$23.99USD on sale at $19.99 USD atm but not available so.....
Jul 25, 2020, 09:52 AM
srepfler's Avatar
I got R9 SX to bind and work,
but can not get Receiver Options to work.
X lite Pro is tx, R9 Pro module ( updated to 1.3 at older firmware bind, but did not move servos),
New Product FrSky New Arrival - R9 STAB OTA long-range and stabilization receiver release AndreaHuang FrSky 46 Aug 13, 2020 06:46 AM
New Product FrSky R9 STAB OTA 16CH 900MHz ACCESS Long Range Stabilization RC Receiver Support PWM alex_nikiforov Banggood.com 0 Oct 14, 2019 11:12 PM
New Product FrSky R9 MM-OTA ACCESS 16CH 900MHz Long Range RC Mini Receiver Support Wireless alex_nikiforov Banggood.com 0 Jul 10, 2019 10:27 PM
New Product FrSky R9 MM-FC-OTA 16CH ACCESS 900MHz Long Range RC Mini Receiver Support Wireless alex_nikiforov Banggood.com 0 Jul 10, 2019 10:23 PM
New Product FrSky R9 Mini-OTA ACCESS 16CH 900MHz Long Range RC Mini Receiver Support Wireless Upg alex_nikiforov Banggood.com 0 Jul 10, 2019 10:18 PM
