New 5" Freestyle Frame for DJI FPV System
Here's a new 5" frame for you freestyle pilots out there using DJI's HD FPV system.
Centurion 5" Freestyle Frame
Here's a new 5" frame for you freestyle pilots out there using DJI's HD FPV system. It features the battle-tested Sköll V3 arms and multiple height and stack options with plenty of room for your gear while still remaining sleek. Check out all the features in the list below. The frame is available from the Flynoshop with a list price of $$79.99. What do you guys think about this drone frame?
Features:
  • Sandwich Style Frame (Simple Assembly and Great for Novices and Experts)
  • Replaceable Arms Compatible with the Sköll V3
  • True X Design Balanced for Freestyle
  • 3 Stack Locations with
  • 2 – 30.5×30.5 Stack Mounts
  • 3 – 20×20 Stack Mounts
  • DJI Air Unit Compatible
  • Dual Fat Strap Capable
  • Compatible with Flyno Tank Printed Parts (Cam Mounts, Antenna Mounts, HD Mounts, etc)
  • Compatible with Sköll V3 Printed Parts (Arm Footies, Couch Mounts, HD Mounts)
  • Stronger 5mm Arms
  • Isolated Flight Stack (Swap Your Arms Without Touching The Electronics)
  • More Space for Components
  • Lots of Integrated Ziptie Holes
  • Micro-Cam Compatible
  • Chamfered Edges
  • Approx. weight (Without HD Mount): 144g
Check out the Centurion 5″ Freestyle Frame Here
May 12, 2020, 05:23 PM
I think it looks great. 👍
I was looking a bit closer and wanted to ask if the vertical connectors (stack mounts?) were metal or plastic? From this photo they look like they could be anodized metal, but I was not sure.
Article 3D Printed Parts for DJI FPV System and FlexRC Colugo Frame Jason Cole Multirotor Drone Talk 2 Jan 31, 2020 08:49 AM
