Apr 07, 2020, 02:50 PM
Help with setting blade 360 with ar7210bx
Howdy I have a blade 360 6s and Iím having a lot of trouble getting it locked in. The tail blow out under hard climb outs and it doesnít seem very locked in. Thanks a lot for any help
Apr 11, 2020, 02:16 PM
Steve_'s Avatar
Originally Posted by Laynelgin
Howdy I have a blade 360 6s and I’m having a lot of trouble getting it locked in. The tail blow out under hard climb outs and it doesn’t seem very locked in. Thanks a lot for any help
Verify you are getting full pitch range from the tail, and try messing around with the tail gain.
Also make sure the belt/pulley is not slipping.
Grab the main gear and try to spin it while holding the tail rotor.
You should feel the belt start to stretch well before it should slip.
Also, don't break your belt.
Disconnect the linkage from the tail servo and manipulate by hand.
It should be buttery smooth with almost zero drag, even while spinning.
Good luck.
May 08, 2020, 08:56 AM
Thanks for the reply I will try that I actually ended up crashing because the tail blew out so I guess Iím rebuilding right now🤔
News The AR7210BX 7-channel DSMX AR7210BX Jim T. Graham Electric Heli Talk 37 Apr 27, 2018 12:04 AM
Help! Help setting up Blade mcx2 with Taranis Moose_FPV Beginner Training Area (Heli-Electric) 8 Apr 12, 2017 02:02 PM
Discussion Need help with Blade 360 CFX to DX6 radio johnathansmith69 Electric Heli Talk 2 Dec 10, 2015 09:54 PM
Discussion Help with setting up a 5-blade flybarless 450 heli NakedHoof Scale Helicopters 0 Oct 07, 2015 05:43 PM
News 3-Blade Conversion Set: Blade 360 CFX ndfly700 Mini Helis 11 Mar 14, 2015 10:23 PM
