SebArt USA New Product Announcements
SebArt has some beautiful birds arriving. Learn more here.
New Products Coming!
SebArt has a container arriving April 24th the trade show that the links provided will show product information, specs, etc. but you will need to email the company directly to coordinate pre-order deposits for the incoming product
1.9M MB339 XS (Available end of May 2020)
The MB339 1.9m Jet ARF was designed by Italian aerobatic pilot, Sebastiano Silvestri and is the big brother to the 90mm MB339. This sport jet model is largely designed off the full-scale MB339 and modified by adding the ultimate aerodynamic ideas of modern pattern models. Combined with Sebastianos 15 years of experience in flying jets, the result are surprising! The innovative design of the MB339 XS is due to the combined lightweight composite fuselage and built-up wood flying surfaces which allows the MB339 an impressive precision and smoothness at any airspeed and flight condition. The Mb339 XS can be flown with a 12 Blade 120mm EDF unit with 12S 5800 mAh LiPo power or a P60 to P70 Turbine, either way this sport jet will perform!
Sebart Mini MB339 (3 min 6 sec)
  • Length: 1.94m
  • Wingspan: 1.90m
  • Weight empty: 8.6 kg
  • Turbine: P60 to P130
  • Hi-Tech composite fuselage
  • painted outside mold
  • Wings and stabilizers in balsa wood covered with Oracover
  • Electric aluminum landing gear and electric brakes
  • Radio: 7+ ch. with 6 MG mini servos +
  • 2 standard for flaps
Learn More Here: https://www.sebartusa.com/online-sto...cts-p187101715
2M Zeus F3A Biplane (Available end of May 2020)
PRODUCTION OF THE ZEUS WILL BE COMPLETE END OF MAY 2020 ALL Zeus ORDERS WILL BE FILLED VIA FACTORY DIRECT WITH A 4 WEEK LEAD TIME.
Final specs will be posted once they have been released.
Learn More Here: https://www.sebartusa.com/online-sto...RED-p119976329
2.2M Miss Ultimate Biplane (Available end of May 2020)
The Miss Ultimate 2.2M ARF was designed by Italian aerobatic pilot Sebastiano Silvestri. This professional ARF model is the result of Sebastianos 20 years of experience in the F3A/3D world. This innovative design combined with the extremely lightweight structure of an all-wood airframe, give the Miss Ultimate 2.2M ARF an impressive precision and smoothness at any airspeed and flight condition. The Miss Ultimate 2.2M ARF will be your dream plane! .....the only aerobatic limit is your fantasy!
  • Wing span: 2.2M
  • Length: 2.4M
  • Weight RTF (GP123): 29 lb
  • Radio: 8+ ch. With 8 High Torque Metal Gear Servos (Futaba BLS177 or similar)
SebArt Miss Ultimate S 2.3m with GP123 engine (0 min 50 sec)
Recomm. Power Setup: Motor: DA 120, GP 123, 3W 110CS
Learn More Here: https://www.sebartusa.com/online-sto...ARF-p187154893
Blanik 50E V2 (Available end of May 2020)
New scale glider version suitable for tug or slope, fiberglass fuselage, balsa and plywood wings and stabilizer structure covered with Oracover, complete with flap, turbine or EDF support, tug release and all accessories, wing bags included.
SebArt Blanik V2 - flight 1 (6 min 40 sec)
  • Wingspan: 130,7 in
  • Lenght: 66,9 in
  • Airframe weight: 7,27 lb
  • Weight RTF apprx.: 11 lb
  • Wing surface: 1247,7 sq in
  • Wing loading: 2,1 lb/sq in
  • Servos function: 7 mini +
  • 1 standard
  • alilerons (2), flap (2),
  • rudder (1), elevator (2),
  • tow release system (1)
  • Share this prod
Learn More Here: https://www.sebartusa.com/online-sto...der-p187160683
3.3M Krill/Seb Art AreS (Available Now):
AreS XL 3D jet kit is a joint product between KRILL Aircraft and Seba Silvestri with the goal of offering a big sport jet kit with ultimate flying characteristics for both precision and 3D aerobatics. Size is set not to exceed European weight limit 25 kg which means the jet is ready to fly with fuel+smoke. To achieve this, they designed an extremely light frame (empty less than 9000 grams) with huge ailerons and flaps on central hinges. Flaps are possible to operate not only as a flaps (flaps move in positive deflection), but by mixing with ailerons as an additional surface for ailerons. Fuselage has a slim, flat and tall shape for great stability during knife edge flight. Elevators and rudder use central hinges as well. Frame is very light but strong enough for extreme maneuvers at medium speeds. For easier transportation you can dismantle fuselage into two pieces, dividing line is behind wings line and turbine. Wings, elevators and fin with rudder are removable as well. Kit is designed to be powered by jet turbines with thrust from 18 kg for sport flying, at least 30kg for 3D flying with vectored jet pipe. The jet is set up for Electron retracts. Front gear door is operated by linear actuator controlled from retract controller or directly from receiver, hinges of front doors are installed. Special designed Kevlar tanks for kerosene and smoke are available, with tanks holder installed inside fuselage. Attaching them is very easy with 4 screws, no additional work is needed. Thrust pipes are offered in 3 sizes and one with vectoring.
AreS flight at Caorle show 2019 (5 min 11 sec)
  • Kit should be equipped with 1 or 2 servos for each aileron
  • 1 servo for each flap
  • 1 servo for rudder
  • 1 servo for each elevator
  • All servos must be at least 25 kg
  • All control surfaces are pre drilled with holes for Gabriel horns that come with the kit.
  • Wingspan: 106.29 in (2.7m)
  • Length: 129.92 in (3.3m)
  • Dry Weight: 46-51 lbs (~20kg)
  • Turbine: 180N and Up
Learn More Here: https://www.sebartusa.com/online-sto...-3M-p158182460
Apr 03, 2020, 12:30 PM
HouseOf4Doors's Avatar
Love the designs!
Apr 06, 2020, 05:48 PM
Bugle6
Saxguy1000's Avatar
I love all the planes, but the videos. When you can't hear the jet flying, half the fun is lost!
Apr 06, 2020, 07:18 PM
Team Futaba
Neilbo4's Avatar
Glad to hear you like the airplanes! Buy one of the jets we have left on the incoming container and you can hear the jet sound first hand
Article E-flite NEW Product Announcement and Latest Releases! Jason M Electric Plane Talk 36 Apr 13, 2020 12:26 AM
Article Three New Product Announcements From DJI Matt Gunn Multirotor Drone Talk 19 Sep 23, 2017 08:20 PM
Discussion New Blade Products Announced BrokeDad Electric Heli Talk 1 Jun 29, 2017 10:26 AM
