The ALL-NEW E-flite Citation Longitude Twin 30mm EDF...The most powerful UMX EDF yet
The E-flite UMX Citation Longitude is powered by 30mm fans and 3S-compatible motors to deliver one of the most unique and exciting EDF jet experiences of any size! Plus it’s equipped with SAFE Select so it’s a great choice for your first twin EDF.
Two ALL-NEW twin EDF models in two weeks :eek: VERY different, very exciting...and maybe a bit crazy too :o
See more info below and on the product pages via this link (PLEASE NOTE: Product page will not be live until the early morning hours PST): https://www.horizonhobby.com/citatio...gn=efl_efl6350
ICON IN THE MAKING
Designed to redefine the super-midsize private jet segment, the Cessna Citation Longitude is expected to revolutionize business travel by offering more range (up to 3500 nautical miles) while carrying greater payloads at higher cruise speeds (up to 550+ MPH). The E-flite® UMX™ (Ultra Micro eXtreme) Citation Longitude is an officially-licensed scale replica of the icon in the making that redefines performance for ultra micro class EDF jets by being the most powerful model in its class yet. With 3S-compatible 30mm EDF power systems, a scale outline and trim scheme, plus functional features including a full-flying stab and LED lights along with exclusive AS3X® and optional-use SAFE® Select technologies, it offers a unique and exciting twin EDF experience – in a size that makes it possible to fly a jet in more places and smaller spaces including at soccer fields, football fields and large parks!
Overview
A UNIQUE TWIN EDF EXPERIENCE
The E-flite® UMX™ (Ultra Micro eXtreme) Citation Longitude makes it easier for more pilots to enjoy a unique and exciting twin EDF jet experience in more places than ever before! Equipped with 3S-compatible brushless outrunner motors and 30mm fans, the UMX Citation Longitude offers more speed and vertical performance than other ultra micro class EDF jet models – and longer-than-average flight times when using the recommended 3S 800mAh LiPo batteries (sold separately). It’s less complex and easier to fly than larger EDF models, and because it’s equipped with exclusive AS3X® and optional-use SAFE® Select technologies, it’s a great choice for your first or next twin-powered jet. It has a scale outline and trim scheme that are officially-licensed by Cessna, plus functional features including a full-flying stab and LED navigation and landing lights. Take off from and land on smooth surfaces using the included landing gear with a steerable nosewheel, or quickly and easily remove the landing gear for launching by hand and landing on grass. With its convenient ultra micro size the UMX Citation Longitude Twin 30mm EDF is right at home at a wide variety of suitably-sized sites including soccer fields, football fields, large parks, and RC flying fields. Best of all it arrives 100% factory-assembled and ready to bind to a compatible 5+ channel Spektrum DSMX/DSM2 equipped transmitter so you can be flying within minutes of opening the box that can also be used for safe and convenient storage and transport!
Exclusive Technologies This model comes equipped with exclusive Spektrum™ AS3X® and SAFE® Select technologies. AS3X works behind the scenes to smooth out the effects of wind and turbulence to deliver a locked-in feel that makes it seem like you’re flying a much larger airplane. Optional-use SAFE Select offers pitch and bank angle limits along with automatic self-leveling that can be turned on and off at the flip of a switch.
Higher Performance The factory-installed twin brushless power systems feature larger diameter 30mm fans with more powerful 3S-compatible outrunner motors. This upgraded power system setup delivers higher performance than the 28mm fans and 2S-compatible motors installed in previous UMX™ models to offer unmatched speed and vertical performance, plus longer-than-average EDF flight times when using the recommended 3S 800mAh LiPo batteries (sold separately).
Functional Features Realistic-looking LED navigation and landing lights plus a full-flying stab are functional features that take your scale flying experience to another level.
Officially-Licensed Modeled after the full-scale Cessna business and private jet, the UMX™ Citation Longitude features a factory-applied paint and decal finish that offers a scale look you’ll be proud to show off everywhere you go.
Fully-Factory Assembled The UMX™ Citation Longitude arrives 100% factory-assembled and ready to fly right out of the box! It’s equipped with industry-leading Spektrum™ 2.4GHz technology that binds to your 5+ channel DSMX®/DSM2® equipped transmitter so you can be flying within minutes of opening the box.
Bind-N-Fly® Completion Level Advantage Already own a Spektrum™ transmitter? Bind-N-Fly (BNF) aircraft make getting into the air quickly and with the best control experience possible easier than ever. They come out of the box with the power system, servos and a Spektrum 2.4GHz receiver installed so all you need to do is bind the receiver to a compatible transmitter, finish any final assembly and fly!
This Bind-N-Fly Basic model is equipped with a Spektrum 2.4GHz DSMX® receiver featuring AS3X® (Artificial Stabilization–3-aXis) technology that works behind the scenes to smooth out the effects of wind and turbulence so you enjoy a sense of stability and precision that makes it feel like you're flying a much larger, expertly tuned aircraft.
If this is your first model of its type, or you want an extra margin of safety while familiarizing yourself with the airplane, you can enable the optional-use SAFE® Select flight envelope protection technology built into the receiver. No programming is required. Simply change up the binding sequence as directed in the manual.
With SAFE Select enabled, you get:
Pitch and Bank Angle Limits • These envelope limits keep the airplane from rolling or pitching upside down. They also prevent excessive climb or dive angles.
Automatic Self-Leveling • The airplane instantly returns to and holds level flight when the sticks are released and in the center position. It’s also helpful for keeping the wings level during takeoffs/launches and landings.
Easy Switch Assignment—No Complex Programming Required • The simple procedure for assigning a transmitter switch to turn SAFE Select features on and off doesn't require any complex programming and takes just a few seconds.
Key Features
  • Officially-licensed scale replica of the Cessna Citation Longitude super-midsize private jet
  • Functional features including LED navigation/landing lights plus a full-flying stab
  • Improved vertical performance and speed compared to other ultra micro class EDF models
  • More powerful 3S-compatible outrunner motors and larger diameter 30mm fans
  • Spektrum™ receiver with industry-leading 2.4GHz DSMX® technology
  • The unmatched stability and locked-in feel of exclusive AS3X® technology
  • Easy-to-fly with optional-use SAFE® Select flight envelope protection
  • Provides real-time battery voltage, current draw and motor RPM telemetry via compatible transmitters
  • Completely factory-assembled and ready to fly right out of the box
  • Lightweight yet durable composite-reinforced airframe and nose
  • Removable landing gear with steerable nose wheel
Specifications
  • Wingspan: 25.1 in (638 mm)
  • Length: 24.9 in (632 mm)
  • Flying Weight: 6.6 oz (188 g)
  • Motor: (2) Brushless Outrunner Motors (installed)
  • Speed Control: (2) Brushless ESCs (installed)
  • Servos: (4) Linear Servos (installed)
  • Radio: Full-Range 5+ Channel DSMX®/DSM2® (sold separately)
  • Receiver: Spektrum™ Receiver with AS3X® and SAFE® Select Technologies (installed)
  • Battery: 3S 11.1V 800mAh LiPo with JST Connector (sold separately)
Needed to Complete
  • Full-range 5+ channel Spektrum DSMX®/DSM2® compatible transmitter
  • 3S 11.1V 800mAh LiPo with JST Connector
  • Compatible LiPo charger
Apr 01, 2020, 10:28 PM
First ...
Apr 01, 2020, 10:30 PM
Fly planes, Be happy
ooOoo's Avatar
Lockheed Blackbird!
Apr 01, 2020, 10:32 PM
32 yrs. Of aircraft Flying!
epoweredrc's Avatar
A twin EDF hummm interesting
No Guts, No Glory!
HuffDaddy's Avatar
Messerschmitt Me-262
F22 Raptor
Originally Posted by ooOoo
Lockheed Blackbird!
Hmmm...that would be pretty cool!! Any other guesses ahead of the official announcement tomorrow?
Apr 01, 2020, 10:37 PM
Jabberwocky_'s Avatar
An airliner (Boeing Dreamliner or Airbus 320 etc.).
Or a business jet (maybe Cessna Citation).
Apr 01, 2020, 10:40 PM
I'd take one (or maybe two...or three!) of each of those!!
Any other guesses??
Apr 01, 2020, 10:41 PM
Hugo Flynow's Avatar
UMX airliner?
F22 Raptor
Me-262... I wish!! But I believe it's been confirmed that it's a civilian model, so that rules out both of those.
Apr 01, 2020, 10:42 PM
You're killin' me Smalls
BrownEyedFool's Avatar
Hmmm
Apr 01, 2020, 10:43 PM
dalecheek1's Avatar
UMX 3D Airliner hahaha
Apr 01, 2020, 10:46 PM
At first I thought it was going to be a new and improved UMX A-10, but with this whole civilian model speculation thing...
Can you confirm that's it's going to be a civilian model, Jason? Someone quoted you on that statement a few days ago, from FB.
Apr 01, 2020, 10:47 PM
Learjet!?
Article The ALL-NEW E-flite A-10 Twin 64mm EDF BNF Basic/PNP...The Easiest to Fly Hog Yet! Jason M Foamy EDFs 1135 Yesterday 09:05 PM
Article The NEW E-flite P-51D Mustang 1.5m BNF Basic/PNP...The Mightiest E-flite Mustang Yet! Jason M Electric Warbirds 1470 Sep 16, 2020 07:40 AM
New Product The NEW E-flite Su-30 Twin 70mm EDF BNF Basic/PNP Jason M Foamy EDFs 138 Jul 18, 2020 11:03 PM
New Product The ALL-NEW E-flite ?-?? Twin ??mm EDF BNF Basic/PNP...The Easiest to Fly ??? Yet! Jason M Electric Ducted Fan Jet Talk 1 Mar 25, 2020 09:43 PM
