Apr 01, 2020, 02:38 PM
Jansvast's Avatar
26" fibreglass FE mono from scratch - second build
Finally here she is! I was only able to pick her up today. The 3d print came out good, but it will be a lot of sanding to get the plug ready for mold making.
The plan:
Joint and smoothen the parts to make a plug. Then, using professional epoxy fibreglass, make a shiny mold for as many hulls as i wish She will be fitted with a flood chamber for worry-free fun.
Power:
4s lipo 4200mah
3670 2280kv
42mm prop for target speed of 80kmh+ (50mph+)
35mm prop for <70kmh long runs
This is my own design, made using FreeShip
This will keep me busy during quarantine for sure
Hopefully youll enjoy following the build
Jn
Apr 02, 2020, 05:56 AM
Jansvast's Avatar
Today i roughlu sanded all irregularities with 100 sandpaper and started filling the strakes and chines, because they printed as little steps. I used excess filler to film the rest.
Apr 02, 2020, 07:41 AM
Closed Account
Just a heads up if you plan on using this as a plug,how well does this plastic handle heat ? ,when you lay your glass and resin over this to make the mould it gives off lots of heat as it cures and may distort the plug ,this is why most plugs arent made from plastic unless its a solid slab carved into a plug . Most use closed cell foam covered in filler of one type or another,i use durabuild filler primer for plugs .
Apr 02, 2020, 08:43 AM
Jansvast's Avatar
I thought about that too, so i asked the epoxy manufacturer how much heat will my chosen system produce because i wanted to use it in a plastic plug, ant they said it wont be a problem (it is 30mins until the system gels up). So thats not a problem thankfully.
I also just came back from a hardware store. I bought a lot of wateroproof sandpaper and PU glue
Apr 02, 2020, 11:38 AM
Jansvast's Avatar
All 4 parts are now together. Glued using pu adhesive. Tomorrow when they will be hardened, i will do lots and lots of sanding. Thats all for now!
Apr 03, 2020, 03:30 AM
Closed Account
What epoxy are you using , in my experience you will be surprised how hot it gets when curing , my fear is your going to see some distortion of the plug so if i were you id start with one thin layer of glass to start so as not to create too much heat and let it fully cure before adding any more layers . Ive built a few plugs and moulds over the years .
Apr 03, 2020, 03:47 AM
Jansvast's Avatar
I dont think it will tell you much, but the resin is LH287 with 30min hardener from Havel composites. I will use gelcoat, too. I was thinking that if it creates too much heat (i will conduct a small test with a few layers first), i can do it in 2 takes, but im afraid that uneven hardening might warp the mold
Left to right: LH 287 resin, H 146 hardener, EG 100-T gelcoat, H 100 gelcoat hardener.
All epoxies
Apr 03, 2020, 04:25 AM
Closed Account
It should tell you in the tech sheet for the specific resin and hardener your using , id read it fully . Id do it in a cool place to allow it to gel slowly and move it somewhere warmer once its gelled to allow it to fully cure .
Apr 03, 2020, 04:46 AM
Jansvast's Avatar
The technical sheet doesnt mention any information about the exotherm, it only says that when it is worked with in 50C+ it might increase the exotherm up to 200C when large batches are mixed (not my case). It also states that the pot life is up to 2h at 25C.
"The exotherm od the system shloud not exceed 50C in 3 layers of 160g cloth. When using hardeners with more than 30min pot life, the temparature increase will be even smaller"
Cited from an email from the company's technical help. The hardener i bought says 1-2h pot life, so i think im entirely safe
Anyway, do you like the hull design?
Jan
Apr 04, 2020, 03:29 AM
Jansvast's Avatar
The sanding is going very well so far. The first layers sanding is almost done, i just have to finish the nose. Then, more filler!
Apr 04, 2020, 05:46 AM
Closed Account
Usually i coat the whole plug with durabuild filler primer or similar product like duratec sands to a smooth shiny finish ready for waxing .You can apply by brush roller or spray equipment sands easy and shines up perfect for moulding from.
1041 Duratec Gray Surfacing Primer (1 min 50 sec)
Apr 04, 2020, 12:08 PM
Jansvast's Avatar
Only if i had a spray gun Being polyester, how well does it sand?
Apr 04, 2020, 05:35 PM
Closed Account
I use a brush to put it on and it sands beautifully .
Apr 05, 2020, 01:49 AM
Jansvast's Avatar
Thanks for the tip. That should make the application a lot easier compared to a classic paste filler. I can get similiar stuff here, too
Apr 05, 2020, 07:52 AM
Closed Account
Yea its cool stuff , obviously theres more sanding to do if using a brush but it really does sand easy and gives a lovely shiny surface once compound polished and buffed to a nice shine .
Build Log Scratch build 1/12 LF-109 Pionyr glider started. Only my second glider project ever. Otakar Scale Sailplanes 35 Jun 15, 2020 01:45 PM
Build Log Jae 26 fe rigger build crapshooter Racing Boats - Electric 18 Jan 07, 2020 09:48 AM
Discussion Building F450 From Scratch scotsman Scratchbuilt Multirotor Drones 4 Nov 17, 2015 10:03 AM
Discussion new scratch build 90mm ducted fan fibreglass wing gazza2003au Australia 58 Oct 19, 2012 07:30 AM
