I'll keep experimenting on my set up to find and observe how and why these retracts demonstrate this toggle issue UPDATE: The requirement to Toggle or "CYCLE" the retracts is CONFIRMED on my bird...sometimes....no matter what position the landing gear transmitter switch is in relationship to the the retract orientation at first battery hook up......after this the airframe can be de-energized and the retracts do not require a switch toggle cycle. TwistedGrin |
The FreeWing A-10 nose gear strut oleo was too soft for our grass runway.....the front prop was striking the ground during normal taxi and probably would have certainly sustained damages during full speed take of and landings.
I managed to take apart the plunger rod and spring and inserted about 8mm cut of 5mm wire strut into the top of the oleo chamber. This does two things....1. Preloads the spring much tighter 2. provides a stop much sooner than stock. Taxi testing of the nose gear with the oleo spacer looks good...the trailing action nose gear still has the ability to absorb bumps, has enough preload to sustain higher weight and prevents the prop from striking the ground at the end of its travel. I think I am ready for the maiden. I ran a quick static test on a starting stand at the field....the HobbyKing "Watts Up" meter displayed the following when hooked up between my ESC's Power lead Y-split and the single battery: 96Amp Peak 2100Watts Peak I am not sure how to interpret the numbers since the single battery running through the meter was tied into both ESC's and motors. This could mean the values are combined and should be split 50% or each ESC/Motor combo represents this value as its own. It could mean each ESC is pulling 96amp's and each motor is producing 2100Watts at static WOT. If so this means the airframe could have 4200Watts of power overall? I am thinking .....each ESC is pulling 48amps and each motor is providing 1050Watts TwistedGrin |
https://www.ilovewwiiplanes.com/2020...BoJyKXqz_xWEUk
This was showing on a news thread I ascribe to TG |
Udvar Hazy is one that I haven't gotten to yet. A guy on youtube did a fairly long video tour of the museum and it turned to be bigger and better than I'd been led to believe -- seems like the same two dozen planes seem to be featured in every story about the museum. U-H is on my short list for must-do trips post-Covid. I did get to the USAF museum in Dayton in May 2019 -- and I was just blown away by the size of the museum and the quality of the examples. We spent two full days and there were still some areas I didn't get to. My only complaint was that the lighting was "weak to horrible" -- I felt like I was wearing sunglasses in some areas. It seems that I read somewhere that they were trying to address this issue -- does anybody know? I'd go back in a heartbeat if the opportunity presents itself. |
Take some time when @ Dullas airport in DC, it's right there. So much to see, easy to spend several days really. From the shuttle, enola gay, blackbird, WAY to much to list, been many times and it never gets old. pristine 335 there, it is huge
TwistedGrin |
Still waiting on a good day to maiden mine.......work has collapsed any chances of evening flights for weeks now. I need to get my reflexes back from not flying for so long. Will fly some easy trainers to get back in shape then see if work and weather give me a shot. I am in no hurry though as I would rather feel good, have the skills up to par and have a weather day. This may not line up for awhile.
TwistedGrin |
It's really not a hard model to fly IMO -- it's mostly a matter of making your knees stop shaking. My best advice is to go back in this thread and watch my maiden takeoff -- that's what a too-far-aft CG and too much elevator throw looked like! Every take off since correcting those two things has been "like butter". If you want me to measure where my elevator throw ended up, let me know.
If I have my COG set up close to yours....your elevator throw should work for me...but I won't hold it against you if I goof anything up - LOL Thanks in advance and Thanks again!! TwistedGrin |
Main gear changes
Finally put the arrow together. Was surprised how the main gear splay out . It would sure add to the bending moment on a hard landing. Sooo, I pulled the gear out and installed Eflite 85 degree 60-120 gear. They fit great but had to go back to a 5mm pin. Now the gear are square with the ground. Also made gear doors out thin plywood and Robart 1/2" gear mounts. Modified the mounts a little thinner and added 6/32 mounting screws. I sure like the new look. I included some pictures I hope came thu.
Main gear changes
forgot one picture.
Thread Tools | |
Similar Threads | |||||
Build Log | Dornier DO 335 Pfeil PSS | MaartenX | Slope | 117 | Mar 02, 2017 08:22 AM |
Discussion | Black Horse Dornier Do335 | TripleW | Electric Warbirds | 4 | Jun 04, 2016 02:54 PM |
New Product | Dornier Do-335 Pfeil by BH Model (68" ws) | Herb | Electric Warbirds | 11 | Feb 01, 2016 09:55 AM |
Contest | Scratch Build Off 3 - Dornier Do 335 Pfeil | michaelghammer | Scale Kit/Scratch Built | 244 | Jan 25, 2012 08:50 AM |
Dornier Do-335 "Pfeil" Build | jcarstan | Slope | 52 | Jan 23, 2006 05:06 PM |
