Nov 25, 2020, 09:13 PM
Hi Nick
Just discovered this thread... Very nice work.
Thanks for taking the time to post with lots of pictures.
Started my build about a month and a half ago and just completed the engine box. Using a DLE 20RA Have a ways to go yet.
Watching with interest.
Ray
Nov 25, 2020, 09:43 PM
It's Tougher in Alaska
AKNick's Avatar
Originally Posted by schmidtsk
Hi Nick
Ray
Thanks Ray!!
In one month I had all the major parts framed, but not finished. I spent most of the summer flying other planes and maintaining them. So now it’s back to the shop to finish this plane up. There have been challenging parts for me no doubt. I’m getting close to covering and painting which excites me. Still lots of fitting and sanding left though
Jan 16, 2021, 10:16 PM
AKNick's Avatar
Hinged the rudder with robart 308 hinges (not in the plans) and finished sanding it.
Jan 16, 2021, 10:25 PM
AKNick's Avatar
Finished sanding the ailerons and flaps using the plans.
Used a PVC pipe with some sticky sandpaper to it, masked off to only sand the tri-stock on the wing thus fitting the flap LE contour a bit better. (Not in the plans) but I liked the idea.
Jan 17, 2021, 12:08 AM
AKNick's Avatar
Figured out how to fix my debacle of the elevator joiner. I received one that wasn’t quite up to par to say the least. Looks like it was tack welded by a new high school student in shop class who got careless with the grinder.
Ended up cutting a slot in the aft side, adding a piece of music wire as a doubler, then silver soldered them together. Cleaned up and painted for corrosion resistance.
Jan 18, 2021, 12:36 PM
Prowler901's Avatar
Good to see you're back at it. Looks like it's coming along well.
Jan 19, 2021, 03:37 AM
AKNick's Avatar
Thanks! Was able to find some time and power through my little roadblocks. Next up is going to be hinging the wing surfaces, and elevator joiner holes. After that I can work on my Rudder control linkage debacle.
Jan 31, 2021, 03:23 AM
AKNick's Avatar
Got to get some tinker time in today!
Worked on hinging the flaps and ailerons with my robart pins (not stock). I ended up with some gaps that required some shims to get to look right. My plans were a little bit off with the laser cut parts and needed some extra time to get the control surface end gaps to all look the same (well closer anyhow).
Decided I wanted to use LED lights (nav, strobe, landing) from a system I designed years ago. I’ve been toying with the idea of using a PCB software to make a circuit board... we’ll see. I’ve made a rats nest version, and a drawn/etched board. But still quite bulky. This could be a fun new venture. But until then I’ll be cutting out the lights and putting the wires in.
Feb 07, 2021, 01:58 PM
AKNick's Avatar
Started stringing some wires for the LED system. NAV, Beacon, Landing Lights, Strobes. I’ve never had any luck with digital switches/relays. If anyone has a lead one let me know. It’ll have to be 12v rated.
I used some old ribbon cable that was given to me and took off what I needed. Super glued the wires to the fuselage and to the wings. You can tell this was an afterthought, so instead of integrating them though the ribs/formers, I went around them.
As for the landing lights I made a square hole for the led to fit in approx 18” outboard of the root rib.
The tail nav, I used a piece of tubing to fit inside the tailcone, just below where the balsa lays.
Feb 07, 2021, 02:05 PM
AKNick's Avatar
Skipped over this part! I drilled and fitted the elevator joiner and opened up a couple areas for clearance.
Feb 07, 2021, 03:04 PM
Prowler901's Avatar
I like the idea of using ribbon cable. Makes the installation look tidier. Are looking for a switch that you can set up on a channel?
Feb 07, 2021, 03:37 PM
AKNick's Avatar
Exactly. I've tried converting an old servo years ago, with no success. I ended up using a couple micro servos and micro switched on a cam setup. That when using a three position switch I could go from nav lights always on, strobes on (second position), landing lights on (third position).
I've been looking at this little kit in which I may be able to reverse engineer and integrate into my own system.
https://hansenhobbies.com/products/rcelkits/erskit/
I was planning on using these for the wing light connectors, and probably the wing servos as well as well:
https://hansenhobbies.com/products/c...ors/200mm_1x6/
Feb 07, 2021, 04:11 PM
Prowler901's Avatar
I have a switch from hobby king that can be plugged in to a RX channel. The leads on the switch can be wired between a power supply and a load.
I like those plug connections.
Feb 07, 2021, 05:18 PM
AKNick's Avatar
I remember looking at those as well. They were always out of stock... come to think of it, I may have actually purchased one a few years ago, but it came with the wires pulled out of the motherboard and I didn't really look into it too much after that. Terrible QC, but hey... you get what you pay for! lol!
Hanson Hobbies is a great resource. They've always been very quick and friendly.
Feb 07, 2021, 10:02 PM
Prowler901's Avatar
Some assembly required. But, they look good.
Alert Free Shipping on 20cc DHC-2 Beaver Kit Dave Eichstedt Scale Fuel Planes 0 Nov 30, 2019 12:21 PM
New Product 20cc DHC-2 Beaver by Moustache Model Works Dave Eichstedt Scale Kit/Scratch Built 5 Sep 04, 2019 11:16 AM
Discussion 20cc DHC-2 Beaver Dave Eichstedt Scale Kit/Scratch Built 3 Jun 06, 2018 04:33 PM
