Mar 26, 2020, 09:46 AM
Sagitta Fanboy
Spektrum AR630 is Coming - SAFE+FP+Antennaless
Was checking something else on FCCID.IO and tripped over a new BRW listing.....
Looks like Spektrum has another 6ch SAFE receiver on the way, this one being an antennaless unit with short range telemetry, although it also lists a bind/SRXL2/Prog port unlike the AR410/AR620's.
https://fccid.io/BRWSPMAR630/Users-M...Manual-4660435
Telemetry is short range like the AR636 and the other Antennaless units, and this has no X-Bus or sensor ports (of course, it should support sensors on SRXL2)
It also includes a neat SAFE Failsafe mode like the AR637T, where you can trigger self-level when it failsafes.
I'm guessing this will be the replacement for the AR636A for BnF's long-term as well as a cheaper SAFE option for those not interested in external sensors other than ESC's, or long-range telemetry.
Mar 26, 2020, 09:54 AM
quist's Avatar
FCC has some privacy issues.
Mar 26, 2020, 09:58 AM
Sagitta Fanboy
Well, if we end up waiting a few months for the release like on the Ar637T, I'll agree.
If it's a couple weeks, it's probably just unexpected delays. The public posting date is selected at filing time.
Mar 26, 2020, 10:58 AM
Dash till Puff
coreless's Avatar
FCC doesn't hide anything all docs are made available to public unlike the other labs across the world.
Mar 26, 2020, 11:09 AM
AndyKunz's Avatar
Mar 27, 2020, 11:33 AM
What exactly is short range telemetry? When spektrum talks about fly by tele, does that mean you have to fly your plane close to your Tx for tele to be available?
Mar 27, 2020, 12:31 PM
Bagpipes spoken here
Pipemajor's Avatar
I believe they describe that as 'fly by' telemetry range. I've heard some HH folks say it's good out to 800 feet or so but don't expect telemetry from beyond visual range.
Mar 27, 2020, 12:37 PM
Sagitta Fanboy
They promise 200-300', but I've seen double that in good RF conditions.
More than adequate for park flyers, but for bigger stuff you may only be getting telemetry intermittently.
These are full range receivers for control links, so ~1.5km is possible with control, but definitely no telemetry at that range on a receiver like the AR630
Mar 27, 2020, 12:54 PM
Dash till Puff
coreless's Avatar
if it's a 'safe' receiver the telemetry is not that important
Mar 27, 2020, 03:45 PM
richard hanson's Avatar
The rx remembers what hAppens to the signal ,out past the telemetry range and once back into telemetry range ,the info is updated
Any disagreements?
Mar 27, 2020, 03:53 PM
I see, thanks guys. Would that also read battery voltage?
Mar 27, 2020, 06:34 PM
Sagitta Fanboy
It will give you receiver voltage, and if paired with a SMART ESC, pack voltage.
It does not include a voltage sensor port to read pack voltage directly, that's one of the extras that the AR637T gives you.
Mar 28, 2020, 11:01 PM
Looks to be a lightweight unit de-cased. Might swap to one of these in my f3p build from the ar620.
Mar 31, 2020, 01:08 AM
BMFA 190658
SilentPilot's Avatar
Short range telemetry has its uses. Slope flying or DLG when you don’t encounter a thermal certainly spring to mind. Like you say Parkflyers too should be ok with it.
If on the other hand you need full range telemetry then add a 4651T on the SRXL2 port. That’s got full range telemetry and will take over the transmission.
Discussion New Antennaless AR410 and AR620 mawz Radios 885 Oct 20, 2020 02:19 AM
Discussion Antennaless Receivers go_hercules Radios 12 May 05, 2019 08:27 PM
Discussion Safe delivery by drone coming to USA Rhea Model Aircraft & Drone Advocacy 5 Mar 01, 2019 04:08 PM
Discussion SAFE+ .. will it come to helis ? BrokeDad Electric Heli Talk 14 Sep 24, 2017 01:08 PM
Discussion Eflite safe receiver or Spektrum safe receiver? bchboy1206 Electric Plane Talk 2 Jun 26, 2016 07:55 PM
