Mar 26, 2020, 09:39 AM
"the analog man"
Question
Setting rates when using a X24
Guys/Jim,
I see how to reverse a servo's direction in the X24. I don't see how to set high/mid/lo rates. I take it I simply set rates in the transmitter as I would if the X24 was not being used? I hope this question makes sense.
Larry
Mar 26, 2020, 12:31 PM
You should be setting the EPA (end point adjustment) for each output port using the X24. The rates themselves are always controlled by the transmitter.
Mar 26, 2020, 01:22 PM
"the analog man"
Jim, Thanks for the info. That is what I thought.
Larry
Discussion 2 numbers when setting dual rate? charbel1011 Electric Plane Talk 14 Oct 15, 2019 01:45 AM
Question Rates when using a go-pro jomonba1 Beginner Multirotor Drones 2 Apr 09, 2019 03:15 PM
Discussion When to use rate adjustment andwhen to use travel adjustment ? cbinfl Electric Plane Talk 27 Aug 26, 2011 07:39 PM
Discussion When to use High/Low Rates andernamen Beginner Training Area (Fuel) 2 Sep 12, 2006 06:01 PM
What charger setting to use when using Kokam 1500 3 cell pack Keith43221 Batteries and Chargers 6 Sep 19, 2004 02:39 PM
