TransTEC FL-6 2-6S Lipo Battery Voltage Checker
There's not a lot you need in your gear bag when you go flying, but a battery checker is a must.
An Accessory You Need
There's not a lot you need in your gear bag when you go flying, but a battery checker is a must. It's a quick easy way to make sure your batteries are charged and in good balance with all of the cells. This TransTEC battery checker is small and looks good too. It can be used with 2-6 cell lipo batteries by plugging in the balance lead from the battery into the checker. It boots up instantly and provides the total pack voltage along with the individual cell voltages, all on a single screen. There are no buttons to press, just plug in the battery and get the data you want. It doesn't get much easier to check your batteries at home or in the field. The TransTEC battery checker comes in 4 different colors and sells for $16.58.
Check out the TransTEC FL-6 2-6S Lipo Battery Voltage Checker Here
Mar 22, 2020, 01:38 AM
Dash till Puff
coreless's Avatar
nice metal case, I don't like how digits are displayed though
Mar 24, 2020, 01:28 PM
ltc
ltc
AMA 97737
ltc's Avatar
10mV resolution is probably ok if the accuracy is good (or if it can be calibrated like an isdt unit)
I've had great luck with my 3 Futaba units so far ...
