This thread is privately moderated by Bchirrick, who may elect to delete unwanted replies.
Mar 17, 2020, 08:15 PM
Builders kit assembly
First step for me is to join the wing halves.
Remove 5-10mm of foam both sides from each wing half. Making sure you remove all the foam attached to the skin also. Gently scrape the foam away from the skin along the edges.
Fill this area with thickened epoxy. Fumed silica and or cabosil. Let cure.
After cured, sand equally both sides to desired dihredral. I’m sanding to 6.5 degrees.
Tape the bottoms together so the wing lays flat on the bench. Add thickended epoxy again to the center joint. Then either prop wing up between two chairs, one flat other raised to desired dihedral, or on my case I prop both sides and weigh down the center. After in place, remove excess epoxy mixture from the joint. Let cure.
I like to drill the wings holes now. Locate where u want the holes. I like 25 and 100mm from the leading edge. I drill small holes making sure they are centered. Then enlarge then to accept the 3mm screws.
With carbon cut out for the center patch, top and bottom. Add center patch closing up the center section. Let cure. Redrill holes and countersink.
Locate the wing mounting nuts for the fuse. Mark and drill two holes to accept the mounting nuts. I make the holes just large enough to pull the nuts through and stay in place on their own. CA in place. Check alignment by measuring from the wing tip hinge line to the tail end of the boom.
Mount the vertical. Using the template, scribe the outline of the vertical. Gently cut this out with an xacto or I like to use a dremel. Gently install the vertical, expanding the opening if needed. Center the vertical using a square checking the hinge line with the center seam in the fuse as well as measuring top and bottom distances. With the wing mounted, flip the airframe over on bench or floor and align the vertical perpendicular to the floor or bench. Use foam safe CA to set.
Drill the desired holes for mounting the horizontal to the pylon. Mount the horiz to the pylon.
Using two tie wraps mount the pylon with horizontal to the boom just in front of the vertical. Looking down the fuse check alignment with the wing. CA in place.
This is where I like to take thickened epoxy and install a fillet on the vertical connection and pylon to boom connection. Let cure.
The model is now ready for your normal build.
Apr 12, 2020, 08:33 AM
Brian,
can you suggest a cg?
Nate
Apr 12, 2020, 11:00 AM
I settled on 68mm
Latest blog entry: Builders kit assembly
May 19, 2020, 04:02 PM
Brent Lytle
How do you recommend measuring for proper amount of wing sweep?
May 19, 2020, 04:25 PM
Lay the two halves together at the root. With either a straight edge or string from one hinge line wing tip to the other, measure the distance from the string to the center hinge line at the root. I set mine to aprox 5-8mm forward sweep.
Discussion First time kit builder: PT-40 vs. Eagle 2 N410DC Beginner Training Area (Fuel) 52 Dec 16, 2018 11:31 PM
Discussion Looking for Kit Suggestions for first time builder and kids rschapel Car Talk 16 Jan 29, 2017 02:11 AM
Discussion Short Kit Cutter Looking for Kit Builders vicsrc Scale Kit/Scratch Built 25 Feb 22, 2016 07:27 PM
Discussion Any local builders/assemblers near Fredericksburg/Spotsylvania, VA? AB Bob The Builders Workshop 0 Jan 13, 2011 05:12 PM
Discussion Need ARF assembler/builder to hire snyder_man Electric Plane Talk 8 Jul 07, 2007 06:29 PM
