This thread is privately moderated by NobatteryNopower, who may elect to delete unwanted replies.
Mar 14, 2020, 12:23 PM
NobatteryNopower's Avatar
Build Log
FPV Classic Range Rover | Axial SCX10 II - Part III
Today I've managed to lay down most of the final paint. It's starting to look quite awesome if I may say so It still needs some touching up and I still have to paint all the black parts. Also, I've been pondering how to utilize a PC Steeringwheel and create working pedals. Steering is easy, just replace the potentiometer of the radio with an extended potentiometer from the PC-Steeringwheel. As most potentiometers of radios work as voltage dividers, the actual Ohms shouldn't matter too much. ...But how to connect a brake and throttle-pedal
I've been thinking how to use both pedals on one radio-channel: throttle-brake-reverse. You can program most car-esc's so that going in reverse starts with braking, and then applying brakes again reverses the car. Practically you do this with one channel. So I came up with the luminous idea of connecting the potentiometer of the brake-pedal to the potentiometer of the throttle-pedal. BUT, the brake-pedal-potentiometer must be of half the resistance of the throttle-pedal-potentiometer. And when the brake-pedal is not pressed ('in rest'), the potentiometer should measure 0 Ohms, thus utilizing the full range of the throttle-pedal-potentiometer when applying throttle, and then when you press the brake pedal, the resistance increases of the brake-pedal-potentiometer, together with 1/2R of the throttle-potentiometer, totaling full range and thus braking. Hit the brake again and the brake-pedal becomes a reverse-pedal.
This works & drives amazing in my brain, but still need to proof this concept in the real world
Hopefully I can order a SCX10 II frame in the next few days. I'll have to make sure the mailman is not quarantined.
Discussion Axial SCX10 II 2000 Jeep Cherokee 1/10th Scale 4WD RTR - Unboxing & First Look SteveDoric Rock Crawlers 6 Sep 29, 2016 06:42 PM
News Axial SCX10 II Jeep Cherokee Kit Matt Gunn Rock Crawlers 13 May 30, 2016 04:54 PM
Discussion Land rover/cruiser Body for axial scx10 trail honcho alexzuga Off-Road Vehicles 0 Sep 04, 2013 12:04 PM
