Mar 13, 2020, 12:04 PM
lost in the addiction of flyin
furballll's Avatar
V2 Skywing 73 inch Extra 300
This is one of the first run of the version 2 73 inch Extra 300 from Skywing-rc.
The plane will be available at NWRC soon
Www.northwestrc.com
Span: 73 inches
Weight: 11.6 lbs wet
Motor: DLE-35RA
https://www.horizonhobby.com/product...ion-p-dleg0435
Propeller: Wood Falcon 20x6
https://northwestrc.com/Falcon-Beech...-GAS_p_73.html
Servos: Savox 1270tg on all surfaces
https://northwestrc.com/Savox-SV-127...izes_p_19.html
Arms: 4 NWRC 1.5 inch 3mm and a 3.25 inch 3mm rudder arm
https://northwestrc.com/NWRC-HD-Arm-...CK_p_2438.html
https://northwestrc.com/NWRC-HD-Arm-...CK_p_2446.html
Receiver: Spectrum AR8010T
https://www.horizonhobby.com/product...ver-spmar8010t
Battery: Single Gens Ace 2200mah 2s lipo
http://www.greathobbies.com/producti...d=GEN22002S45C
This plane is one of the easiest planes I have ever had the pleasure to assemble. The DLE-35RA is a perfect fit on this plane as it was designed around it. The flight capabilities of the Extra are unsurpassed in this size. The tail authority allows the plane to tumble within its length. The slow and low performance is predictable and consistent.
With this early production of the v2 plane had only one item that needed addressing, and I know that all further production will be reinforced by the factory. The rudder servo tray was able to move 1/4 inch back and forth, this was cured by one simple reinforcement. At the front of the tray.
Mar 13, 2020, 12:05 PM
furballll's Avatar
A few more shots. Finally had a chance to get some if flight shots, its hard to do when your the photographer in the family and the pilot but today I was fortunate enough to finally get Geno to fly it for me.
<iframe width="560" height="315" src="https://www.youtube.com/embed/eArHM32U3uQ" frameborder="0" allow="accelerometer; autoplay; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
Mar 14, 2020, 12:21 PM
Crazy 3D
Crazy 3D's Avatar
A video would be great
Mar 14, 2020, 02:03 PM
furballll's Avatar
One is coming up as soon as I can get my friend to fly the plane. I can't fly and film, and my family that's been out with me can't film.
Skills are a real life problem.
May 24, 2020, 06:40 PM
furballll's Avatar
Here is a long awaited video. Stupid covid. Geno was a bit rusty since it was his birthday party the night before, but this shows how amazing the performance of the plane is.
Skywing 73 inch extra 300v2 (4 min 56 sec)
May 25, 2020, 01:49 AM
Wow nice flying
May 25, 2020, 08:25 AM
34 years of flight.
epoweredrc's Avatar
That is why i use my headcam 99% the time. its hard to get someone to video if you fly alone a lot. plus normally my headcam catches my whole flight and up closer then someone else who would be doing a video.
https://youtu.be/eArHM32U3uQ
but whoever was filming that did great job and beautiful day for it and great flying.
Jul 23, 2020, 07:37 PM
furballll's Avatar
Here is the image of the updated rudder tray support in the newest edition of the plane.
Jul 25, 2020, 04:34 PM
furballll's Avatar
Anyone doing a build and wondering about balancing. This is how I set mine. Its dead neutral at this point. My fingers are on the cross support at the rear of the wing tube.
Jul 26, 2020, 10:36 PM
Fallguy44's Avatar
Thank you. Starting on Wednesday.
Jul 30, 2020, 10:36 PM
Fallguy44's Avatar
So the control horns that are glued/expoxy'd in. The 2 smaller sets go on the rudder?
And I also can't figure out how the elevators go on with the magnet system. It's late and I feel dumb at the moment. I imagine it's super easy.
Jul 31, 2020, 12:54 AM
furballll's Avatar
Yes they are epoxied in on mine, I have seen others use different glues but I prefer epoxy. I suggest a complete dry fit to verify the correct placement.
as for the elevator retainers
step one pull pin
step two lift lock
step three put elevator on carbon rod and seat it to fuse
step 4 lower lock in place
step 5 put in pin.
super easy to do and effective, removing them for transport requires disconnecting the linkage if you decide to, I have never needed to as of yet.
Enjoy the build and remember not asking a question and screwing up is worse than any late night stupid question
Jul 31, 2020, 06:57 AM
Fallguy44's Avatar
step one pull pin
step two lift lock
step 5 put in pin.
Thank you. Yes I always use expoxy as well.
Just want to confirm that the shorter control horns go to the rudder before I epoxy them in.
Jul 31, 2020, 11:53 AM
Fallguy44's Avatar
Got the elevators on and there is a little bit of play back and forth on both sides? Normal? Not really liking that. I may epoxy those in. I have no need to remove the stabs
Jul 31, 2020, 04:39 PM
furballll's Avatar
Mine has some movement as well. Sure can't feel it in the air. Try it, if it still bothers you glue it then.
New Product Skywing 89" Extra 300 guldukat 3D Flying 6 May 01, 2019 03:58 AM
New Product Skywing 101" Extra 300 guldukat 3D Flying 14 Apr 09, 2019 07:09 AM
Discussion SKYWING - 73"-Slick360 Share and discussion EDGE540T 3D Flying 246 Dec 28, 2018 03:06 AM
Discussion Next Plane: Extreme Flight Extra 300 78" or AJ Aicraft Laser 230Z 73" bbrc77 3D Flying 8 Oct 19, 2017 02:23 AM
Discussion 60 inch edge 540 vs 48 inch extreme flight extra 300 & edge 540 vs 3dhs slick 51 & 59 CRFan1 3D Flying 40 Mar 04, 2012 03:45 PM
