Mar 07, 2020, 09:15 PM
Spektrum S2100 Smart Charger - Storage Charge
I have a new Spektrum S2100 Smart Charger that I am using to charge SPMX50004S100H5 ---- 5000MaH 4S 14.8V 100C batteries. I used the four batteries today in my 1/5 Scale Losi and then did a storage charge on all four batteries. Three of the batteries complete the storage charge and indicated that the charge was complete.
The last battery is still charging at 0.1A. The cell voltage is:
1. 3.78
2. 3.78
3. 3.78
4. 3.80
The charges has been going on for about 55 minutes.
How long does the storage charge usually take?
Mar 07, 2020, 10:10 PM
Is it trying to **balance** charge at that voltage?
Usually shouldn't, does take lots longer
Mar 08, 2020, 10:06 PM
What IS the proper way to plug in the balance plugs?
Mar 09, 2020, 07:48 PM
The balance port on the S2100 configuration is show on page 3 (US English) in the manual. When looking straight at the plug the balance connector would plug into the connector starting on the left side.
If you are using a Smart Battery I do not think you need to use the balance port.
Mar 10, 2020, 08:59 AM
Fly 'm if you got 'm
MrEFlyer's Avatar
Storage voltage does not need to be so precise.
Stop the charge and put the batteries in their safe container.
Mar 11, 2020, 06:09 PM
Fire Marshall Bill
You SHOULD use the balance lead on every charge.
Plugs in with the lugs facing down and all the way to the left.
I have painted the area around the socket white. Makes it much easier to see.
Spektrum should have made the port orange like the main plug for visibility
Mar 11, 2020, 06:36 PM
Recreational Model Plane Pilot
Rhea's Avatar
If you are suggesting the need to balance when putting a battery into storage,
please explain.
Mar 11, 2020, 07:27 PM
Space Coast USA
hoppy's Avatar
As strange as it may seem, balance charging a normal pack in a discharged state actually imbalances it. Most of the time, the cells will have slightly different capacities and therefore will end up with slightly different voltages when discharged but will end up balanced when charged without the need for strong balancing when fully charged. Balancing the pack when discharged will demand more balancing when fully charged than if not balanced when discharged.
Mar 12, 2020, 09:16 AM
Fire Marshall Bill
I am suggesting that you should use the balance lead regardless of the battery type (SMART vs normal)
Spektrum S2100 Help, alibaloch94 Batteries and Chargers 5 Feb 29, 2020 07:11 AM
Storage charge and charger questions i_am_mark_evans Batteries and Chargers 6 Sep 25, 2016 03:19 PM
Why my charger discharges if charging for storage cyberprodigy Batteries and Chargers 2 May 16, 2016 03:12 PM
Prophet Precept 80W LCD ACDC Battery Charger, 20% storage charge??? Rich2wd Batteries and Chargers 4 Mar 23, 2016 12:04 PM
