Mar 07, 2020, 10:19 AM
Goes to eleven!
JK13's Avatar
Build Log
Fieseler Storch Build Thread - Storchschmiede 1:3.5 Scale
All,
I thought I would send some info on this full composite kit from Storchschmiede (Storch Factory) in Germany as it has been a very positive experience.
Following a very good experience building the big 1/3 Wilga from Tomahawk Aviation also in Germany (also all composite) I wanted to try another.
The full scale model of the Storch is mostly fabric covered and while that would naturally lend itself toward a fabric covered model, the composite version (Storchschmiede offers both types of construction) I chose for the ease of build, strength and light weight (significantly lighter they say).
The molded parts have amazing detail and are the finest I have experienced.
The engineering accuracy of all of the various location markings and parts of this model are excellent and this makes it much easier to put together!
See some pics below from the Storchschmiede site:
http://storchschmiede.de/index.php?o...=92&Itemid=583
Note that the detail molded in includes all of the pinking tapes, and even the grain of the fabric covering from the master model that the molds were taken from.
Note: the model was designed by Alfred Benzing at Storchschmiede and he had the composite molding done by Thomas at Tomahawk Aviation.
More to come!
Joe
Mar 07, 2020, 10:26 AM
Goes to eleven!
JK13's Avatar
Here are a few pics of a finished 1/4 scale Storchschmiede Fieseler Storch also composite:
Joe
Mar 07, 2020, 10:37 AM
Goes to eleven!
JK13's Avatar
I started this build on Dec 27th and will post pics of some of my progress-
Joe
Mar 07, 2020, 10:40 AM
Goes to eleven!
JK13's Avatar
The day I started was looking over all of the fiberglass/carbon composite parts and planning where to start.
Joe
Mar 07, 2020, 10:43 AM
Goes to eleven!
JK13's Avatar
As this will not be a full build thread, I will post the highlights of the build and answer questions that you might have-
Joe
Mar 07, 2020, 10:45 AM
Goes to eleven!
JK13's Avatar
First thing I did was rough cut-out the windows to help access the cabin for the build.
I carbon fabric lined the bottom of the fuselage to add strength for when you pick up the model it will prevent flexing and cracking later - I did this on the big Wilga and it worked great!
Joe
Mar 07, 2020, 10:52 AM
Goes to eleven!
JK13's Avatar
Here are some pics of the carbon tubes I added just like the full scale and also trying on the landing gear for the first time!
Joe
Mar 07, 2020, 11:07 AM
Goes to eleven!
JK13's Avatar
This model has a wingspan of 4 meters (157 inches)
I estimate it will weigh around 50-55 lbs when done with all the scale bits added.
The big Wilga (3.7 meters) weighed 65 lbs wet with all of the added scale features and flew amazing (slow and light) - these are big planes that fly great (a lot of wing!)
Mar 08, 2020, 01:05 AM
Goes to eleven!
JK13's Avatar
More carbon tubes added and glued inplace with Hysol epoxy
Over 100 carbon tubes added - really stiffens the structure.
Replicates the steel tube fuse on the original.
Joe
Mar 08, 2020, 01:07 AM
Goes to eleven!
JK13's Avatar
Also note the plywood tow hook/servo setup on the upper mid fuselage.
Joe
Mar 08, 2020, 09:39 AM
Goes to eleven!
JK13's Avatar
The door was carefully cutout using the Dremel saw blade - very thin line to minimize the cut width.
Also see the size of the plane with the wings on while I am trial fitting the wing joiners. - the fuse is around 9 feet long!
Joe
Mar 08, 2020, 09:45 AM
Goes to eleven!
JK13's Avatar
The engine is from Roto in the Czech Republic
They specialize in four-stroke motors and make them for UAV's and model airplanes.
This is a beauty! - all CNC machined and even came in a nice wood box.
Engine model is - Roto 130 FSI
The three cylinder inline should fit nicely into the long cowl of the Storch.
I will make a custom scale exhaust and that will be a challenge!
Joe
Mar 08, 2020, 09:13 PM
Goes to eleven!
JK13's Avatar
On many of my planes I stand them on end to align the motor to the cowl for centering.
On most kits, the motor alignment marks are rarely accurate.
So what I do is secure the fuse in a vertical position and set the motor on the motor mount and put the cowl into accurate place.
Then move the motor around till it is perfectly centered and carefully remove the cowl and mark the motor position.
Joe
Mar 08, 2020, 09:17 PM
Goes to eleven!
JK13's Avatar
With the long engine and with the right/down thrust-line, I had to mount the engine slightly off of the side of the motor mount so I made a plate from 1/4" 6061-T6 aluminum plate to carry the load off to the side and still have four secure bolts thru the motor mount.
Joe
Mar 08, 2020, 09:21 PM
Goes to eleven!
JK13's Avatar
Motor well centered!
Joe
Build Log Fieseler Storch 94" (1/6th Scale) Ounooi Balsa Builders 18 Mar 26, 2020 11:22 PM
Build Log Fieseler Fi-156 Storch - Svenson Design, 1/6 scale build Trogster Scale Kit/Scratch Built 2 Oct 20, 2019 12:19 PM
Gallery Fieseler Fi156 "Storch" 1/4 scale Electrik 25 kg. dappopao Scale ARF/RTF 1 May 25, 2013 05:43 PM
